Cosimo Bullo
How does thr extended tele look?
is it comparable to a 4k crop
It's amazingly good, I'd say. At 200 mbps it's more than an equivilent of a 4k crop, especially at 60p.
What model of speed booster are you using?Here are my camera settings:
lens: Tokina 11-16mm w/ Metabones Speedbooster
f-stop: 2
shutter: 1/25th
ISO: 200
Picture Profile: Cine-D -5, -3, -5, -2, +0
Curve: +5 Shadows, +0 Highlights
i.Dynamic: Standard
Wow thats very interesting! So its way better than the regular 1080p i presume? Please post some comparisonsIt's amazingly good, I'd say. At 200 mbps it's more than an equivilent of a 4k crop, especially at 60p.
This is an in-camera down-scaling issue that potentially could get fixed via a future firmware upgrade.
You can hope, but when was the last time Panasonic made any real improvements to a camera via a firmware update?
Has anyone made any more tests on the GH4's Dynamic Range? No one has done tests that show anything better than eight or so stops. Im considering moving from the GH3 to the GH4 but probably wont bother if there is no improvement on DR.
Thanks for sharing your settings, dvbrother! I'll have to give them a try!
I agree that if i.Dynamic adjusts per scene then it is a major issue. If anyone can find proof of it, I will amend my thread's first post to avoid leading others astray
I have been trying to trick my cam into getting i.Dynamic to misbehave but so far no luck. I am on Low most of the time though.
If anyone can record it being naughty, that would be great, of course.
Yes, I 100% agree that Cinelike-D doesn't offer a huge dynamic range increase over the other modes. Furthermore, once you start playing with contrast, highlights / shadows, etc... most modes can be so low contrast that they bump into the noise floor.
I was just playing with Natural today... it appears to be pretty much Portrait with less saturation, which is awesome as a big problem I was having was that I couldn't turn saturation down enough.
Comparing Natural and Cine-D, I think that Natural even allows for less saturation than Cine-D. And Cine-D has really weird color bands in the highlights for me (or at least, it saturates the highlights to the point where the distortions in the color science become more obvious).
Bruce Allen
www.boacinema.com
Yeah, I kind of settled on standard for my outdoor shots. Works pretty well. Really don't make any adjustments except for knocking down highlights just a bit on the curve. (-3, I think)
Bruce, regarding those Stouffer wedges, I found a page for them (http://www.stouffer.net), but which model is the right one to get for film/video application? Also, if I'm understanding it correctly, they only seem to cover about 6 or 7 stops depending on model, so to test the full dynamic range of the camera do you just take multiple shots at different exposures?
Shenan, the T4110 is the one you want as it has the most dynamic range. Well, get the C version if you want them to actually calibrate and check it.
You can also get the DSC Labs Xyla but that is thousands of dollars.
The T4110 has a fine camera test heritage, eg Barry Green has been known to use it:
http://www.dvxuser.com/V6/showthread.php?187624-GH1-meet-the-Stouffer-4110C-dynamic-range-test
And RED has been tested on it here:
http://bealecorner.org/red/test-080108/page2.html
Heck, I even used it to test a HV20 back in the day.
The main issue with the Stouffer is that there is a little bit of cross-contamination of light which lessens DR. You want to have no light other than whatever is backlighting the Stouffer in the room as well.
Only with the very best cameras (F35, Alexa, Dragon) would the dynamic range of the Stouffer be too little (in which case, yes, you need a chart with more DR).
I have actually ordered 8 Stouffer charts so that I can put various gels in front of them to see what is happening with color across the dynamic range spectrum in one shot easily.
Bruce Allen
www.boacinema.com
