I noticed that 1080p recording has much more noise than 1080i. Why is this?
iam just wonderin if the hvx has this so called "noise" issue, then why is it being used on feature films. i think the talk of noise all the time is making the hvx look bad
Well, that part's not true -- the FX1/Z1 have a lot less noise than the HVX does. The HVX is about the same noise level as the rest of the HDV cams, but the Sonys are noticeably cleaner.The HVX has less noise and more color depth than any HDV camera.
No long-GOP compression blocking, that's true. It can happen on HDV, it remains to be seen whether it happens on the EX1 or not.And no compression blocking like the HV20 or EX1
HDV is 25mbps, not 50. It's 1/4 the data rate of the HVX. But the bandwidth is used differently -- sometimes HDV looks fantastic. Sometimes it falls apart. You can't just make an arbitrary judgement based on the bandwidth (100 vs. 25) because they're not used the same way.Cramming HDV into 50bps is half the possible information of the HVX's 100bps.
It's possible to get some mosquito noise in 720, but you should find that it basically disappears in 1080.What makes me sad is the HVX mosquitto fine noise... looks like DB noise.
Ulisses
I'm curious to see a HVX footage in the big screen.
Ulisses
