HVX 200A Brochure
peter orland
Not sure whether this already up here but I have a PDF Brochure for the 200a but I couldn't upload it as it is a 1.1meg file and the limit is around 500k. Any way I can post it here?
On the front page it says "It has A powerful 13x zoom lens with a wider, 30mm angle of view (35mm equivalent), and a new progressive CCD greatly improves S/N ratio and lowers smear.
I'm at work so it would be easier if if I could post it on the site?
dude are you kidding? are you seriously holding a broshure for the new hvx before NAB? how in the hell did u do that?
hell yeah, go to member upload center at the middle top of the page and you can submit pictures or whatever you want, ohh gosh tell me more tell me more we are dying to know what the features of the new hvx are
Here is most of the print text + the specs. Hope it's of interest to some of the members. Got to get back to work.
Cheers Pete.
Panasonic's handheld P2 HD camcorders are packed with advanced video technologies. The AG-HVX200 is widely
praised as a revolutionary professional production tool for an array of applications, from filmmaking through
broadcasting.
The P2 card's excellent mobility, reliability and instant playback ability were proven in demanding applications in the
field, from the one-chance-to-capture-it pressure of the Olympic Games to the extreme weather of the Iditarod in
Alaska. Features like the DVCPRO HD codec's high image quality, variable frame rate recording — the first ever in a
handheld camcorder — and the HD/SD multi-format with built-in DV tape drive were appreciated by video creators
everywhere. The original AG-HVX200 continues to provide new solutions to the production of movies, documentaries,
short movie features, and more.
Now, the P2 handheld camera takes another step forward. The new AG-HVX200A with its newly-developed CCD
raises the signal to noise performance while enhancing the low-light performance of the camera as well.
Coupled with a new 30mm wide-angle zoom lens, this new version of the HVX200 addresses even more applications
and meets the needs of user with more critical needs.
The Leica Dicomar® HD Lens
Developed specifically for HD recording, this lens system features a
large 82-mm (diameter) filter along with 15 lens elements in 11 groups,
including three aspherical lenses.
The Leica Dicomar lens incorporates Leica optical technology and
know-how throughout. The use of low-dispersion glass reduces color
aberration and increases resolution, while a multi-coating process
minimizes flare and ghosting. This results in sharp, crisp, beautifully
rendered images with delicate nuances and exceptional shading.
*Leica and Dicomar are registered trademarks of Leica Microsystems IR GmbH.
Wider-Angle 13x Zoom Lens
The powerful 13x zoom lens, specially designed for HD recording, has
a wide 30mm angle of view (35mm equivalent). The new lens, which is
based on Panasonic's acclaimed wide-angle lens design, covers most
shooting situations without requiring a wide-angle conversion lens. Its
minimum object distance (MOD) of about 1.9 ft (0.6 meter) at the
telephoto setting helps to maximize the handheld camcorder's
inherent mobility.
Panasonic's advanced OIS (Optical Image Stabilizer) dramatically
reduces the blurring caused by hand-held camera work. Optical
processing with an automatic correction function helps assure
consistently clear, sharp images.
New Progressive CCD and DSP
Achieve Higher Sensitivity and Image Quality
New Progressive CCD Raises Sensitivity and Lowers Noise
and Smear
The new 1/3-inch 16:9 progressive
CCD on the AG-HVX200A further raises
image quality. It combines a
significantly improved S/N ratio and
better low light performance than
previous models. Backed by a
high-performance digital signal
processor, the CCD brings higher
quality to HD images to meet the demands of broadcasters and
high-end video producers.
DSP with 14-bit A/D Conversion and 19-bit Processing
The AG-HVX200A's developed digital
signal processor for 1080/60p video
signals uses 14-bit A/D conversion and
19-bit inner processing to attain
unprecedented accuracy. While the
camera does not record 1080/60p, it is
from this capture that all other signals
are made. The DSP performs a variety
of adjustments, including eight types of
gamma settings, for each of the R, G and B channels. It also converts
the signals to HD or SD format. With a performance equivalent to the
processors used in many higher-end HD cameras, this new DSP helps
the AG-HVX200A deliver beautiful images in all video formats.
GENERAL
Supply Voltage: DC7.2V / 7.9V
Power Consumption: 11.6W (when viewfinder is used), 12.0W (when LCD monitor is used)
MAX 14W
Operating Temperature: 0°C to +40°C (32°F to +104°F)
Operating Humidity: 10% to 85% (no condensation)
Weight: Approx. 2.5kg (5.5 lbs) excluding battery and accessories
Dimensions (WxHxD): 168.5 x 180 x 390 mm (6-11/16" x 7-1/8" x 15-3/8")
CAMERA
Pick-up Device: 3CCD(1/3-inch interline transfer type and progressive modes supported)
Lens: LEICA DICOMAR lens with optical image stabilizer,
motorized/manual mode switching,13 x zoom,
F1.6 to F 2.8 (f= 4.2mm to 55mm) (35mm equivalent: 30.3mm to 394mm)
Optical Color Separation: Prism system
ND Filter: 1/8, 1/64
Gain Selection: 60i/60p mode: 0/+3/+6/+9/+12/+18 dB
(when using slow shutter, 0 dB fixed)
30p/30pN/24p/24pA/24pN mode: 0/+3/+6/+9/+12 dB
(when using slow shutter or VFR rate of less than 24p: 0 dB fixed)
Frame Rate: variable 12/18/20/22/24/26/30/32/36/48/60 fps (frame/sec)
Shutter Speed: 60i/60p mode: 1/60 (OFF), 1/100, 1/120, 1/250, 1/500, 1/1000, 1/2000 sec.
(Preset) 30p/30pN mode: 1/30, 1/50 (OFF), 1/60, 1/120, 1/250, 1/500, 1/1000 sec.
24p, 24pA, 24pN mode: 1/24, 1/50 (OFF), 1/60, 1/120, 1/250, 1/500, 1/1000 sec.
Shutter Speed: 60i, 60p mode: 1/60.0 sec. to 1/249.8 sec.
(Synchro Scan) 30p, 30pN mode: 1/30.0 sec. to 1/249.8 sec.
24p, 24pA, 24pN mode: 1/24.0 sec. to 1/249.8 sec.
Aperture Angle: 10°to 350° (Shutter Angle is selectable under Film Cam Mode.)
Slow Shutter Speed: 60i/60p mode: 1/15, 1/30 30p/30pN mode: 1/15 sec.
24p. 24pA, 24pN mode: 1/12 sec. (only in 720p mode)
Minimum Luminance: 3 lx (F1.6, +12 dB gain, at 1/24 shutter)
Lens Hood: Large lens hood with wide view angle
Filter Diameter: 82mm
Video P2 General (DVCPRO HD, 1080i/720p)
Sampling Frequency: Y: 74.25 MHz, PB/PR: 37.125 MHz
Quantizing: 8 bits
Compression: Compression ratio 1/6.7, DCT + variable length code
Recording Bit Rate: 100Mbps
Audio P2 General (DVCPRO HD, 1080i/720p)
Sampling Frequency: 48 kHz / Quantizing 16 bits / 4ch
Frequency Characteristics: 20 Hz ro 20kHz
Memory Card
Recording Format:*1 DVCPRO HD
1080/60i (30p over 60i, 24p over 60i, 24pA over 60i),
720/60p (30p over 60p, 24p over 60p),
720/30pN (Native Record), 720/24pN (Native Record)
DVCPRO 50/DVCPRO/DV
480/60i (30p over 60i ,24p over 60i, 24pA over 60i)
Audio Recording Format: PCM digital recording 48 kHz /16 bits
4ch (DVCPRO HD/DVCPRO 50), 2ch/4ch selectable (DVCPRO/DV)
Recording Time*2: 32 minutes with one AJ-P2C032RG (DVCPRO HD, 1080/60i)
(Approx.) 80 minutes with one AJ-P2C032RG (DVCPRO HD, 720/24pN)
VTR part General
Recording Format: DIgital Video SD
Tape Format: Mini DV cassette (6.35mm width metal evaporated tape)
Recording Video Signals: 480/60i (NTSC Digital Video, Standard Definition),
24p/24pA/30p mode (all convert to 480/60i and record)
Frame Rate: 60i (480i), 24p, 24pA, 30p
Recording Audio Signals: PCM digital recording, 16 bits: 48kHz/2ch or 12 bits: 32kHz/4ch
Wow & Flutter: Below measurable limits
Recording Tracks; Digital video / audio signals: helical track
Time code: helical track (sub-code area)
Tape Speed: SP mode: 18.812mm/sec, LP mode: 12.555mm/sec
Recording Time: SP mode: 63 min. (When using AY-DVM63MQ)
FF/Rew Time: Approx.140 sec. (when AY-DVM63MQ is used)
VIDEO connectors
Video Out: Analog component, Y: 1.0Vp-p , 75Ω, PB/PR: 0.7Vp-p , 75Ω
Video In/Out: Pin Jack x 1, Analog composite, 1.0Vp-p , 75Ω
(In/out automatically switched, Input DV tape mode only)
S-video In/Out: 4-pin, Y/C Y: 1.0Vp-p , 75Ω, C: 0.286Vp-p , 75Ω
Component Analog Out: D-Connector for HD Images
AUDIO connectors
XLR In: XLR (3 pin) x 2 (Input 1/Input 2), Input: High impedance
Line: 0dBu, MIC: –50/–60 dBu (selectable in menu)
Line In/Out: Pin Jack x 2 (Input 1/Input 2), (automatically switched),
In: High impedance 316mV, Out: 600Ω, 316mV
Internal Microphone: Stereo Microphone
Phones: Stereo Mini jack (3.5mm diameter)
Internal Speaker: 28mm round shape x 1
OTHER connectors
IEEE 1394: 4-pin Digital input/output, based on IEEE 1394 standard
USB: Type mini B connector (USB ver.2.0)
Camera Remote: Zoom, Rec (Start/Stop) Super Mini jack (2.5mm diameter)
Focus Iris, Mini jack (3.5mm diameter)
DC Input: 2P x 1, 7.9V
Monitor, AC Adapter, and Other packages
LCD Monitor: 3.5 inches, LCD color Monitor, 210,000 pixels
Viewfinder: 0.44 inches, LCD color Viewfinder, 235,000 pixels
AC Adapter: Weight: 160g, Dimensions: 70 (W) x 44.5 (H) x 116 (D)mm
Supplied Accessories: AC adapter/charger, AC Cord, DC Cord, Battery (5400mAH),
Wireless remote controller (Button-type battery), Microphone holder,
Eye cup, Shoulder strap, Ferrite core, Component Video cable,
Pin-BNC conversion plug, P2 card software driver install (CD-ROM )
*1: For the precise recording rate, multiply the indicated value by 1/1.001.
*2: Time shown above is when you record a series of 1 shot to P2 card.
Depending on numbers of shots you record, time will get shorter than the number shown above.
Hey Peter, here are some options....
1st, try to export-"save as" the PDF in Acrobat as a PNG and/or jpeg.
Then, post the images accordingly as you've done with the front cover.
At the same time, I would also suggest uploading the entire PDF to Zshare.net.
Then, post the link they provide to you for downloads in this thread.
If you're unable to do this, try to PM Luis Caffesse, who started the HVX200a wishlist thread.
He may work with you to get something posted.
Keep in mind, assuming you've obtained a PDF that is destined to be shared with us all at NAB, you only have roughly 24 hours before being proven right or wrong, most people may just choose to hold their water on this till then.
My question is, how did you obtain this PDF and do you personally believe it is legitimate?
Anything about it in particular that strikes you as being odd or unexpected?
EDIT: Thank you Peter.
You've obviously chosen to take the time to post an update with the specifications, however I think the PDF and/or images should still be posted as well.
no, it seems that the only changes were to the lens, ccd low light performance, no improved LCD, and +18dB gain. I'll be keeping my HVX :)
Panasonic missed the boat. If this is true it will not raise sales at all. Nobody will upgrade from the 200 to the 200A since the differences are to small. Why didn't they improve the LCD, flip frame, increased the resolution of ccd's a bit. I think a lot of potential buyers will switch to Sony now. I am not sure yet since I can not believe that these are the only improvements. Maybe Jan C.-L. can give us a summary of the improvements tomorrow !!!!!!!
I think there will be a real successor announcement at the end of 2008 because I don't believe that this is the only thing Panasonic can come up with. It has to be a completely different cam.
It may not be a revolutionary release; but, Panasonic absolutely addressed a couple of key items on the list:
1. Better low light and image quality
2. More lens features (albeit not a replaceable lens)
Good job Jan.
I imagine the revolutionary change will come along with a different platform altogther.
(although, the brochure does not mention any potential software changes that may be in there for this round)
Come on...at the least I figured a new LCD would be in order. That would be one of the easiest to fix for cripes sake. I guess we'll have to see just how much better its footage it. Odds are it'll be hard to see and not warrent a new purchase unless your buying one for the first time.
can you tell us the highlights of what the brochure says????
Already posted:
The April 14, 2008 issue of "TV Technology" magazine contains a Panasonic P2 HD insert. The HVX200 is listed as the HVX200A. The description is: "This remarkable camcorder features all the fabulous features and benefits of the HVX200, plus improved progressive 3-CCD imagers and a DSP that increases sensitivity, while lowering noise and smear. A new 13X zoom lens provides a wide 30mm viewing angle ..."
The insert also shows the AG-HPX170 Fully Solid State, 1/3" 3-CCD Handheld Camcorder. The description is: "This smaller, more powerful, go anywhere DVCPRO HD camcorder offers a wide angle Leica Dicomar lens, two P2 slots for continuous recording, HD-SDI and IEEE 1394 interfaces, NTSC/PAL switchable, a time/date stamp function, and more variable frame rates than prior P2 HD handhelds. It comes with our 5-year limited warranty."
I'd rather have improved low light sensitivity and and greater resolving capability than a new LCD.
A new LCD would be great but I'd rather have the other stuff first. You can make do with the current LCD and focus assist works great for me.
But, I don't have any control over low light sensitivity or resolving power.
damn if this is true i am buying the new sony cam asap, i cannot beleive that this is the only major changes that were made, if sony fixed the rolling shutter and lens problem that the other cam, this new sony cam is going to kick everyone's asses all over the place, panasonic you let me down
