Hi guys,
I wonder if all the comparison is right here? I assume most of the potentional new owner has/had cheaper prosumer cameras. Sometimes it seems like the "real pros" here compare this camera with more expensive ones...
Anyway - I'm really considering buying the HPX301E (european version, I assume same as 300). After reading most threads about the cam, I still have a few questions.
First: Until now I've been using a Canon XHA1 (HDV-3CCD). Quite pleased, but want a better cam. That said - that's what I want to compare to...
1. There is a lot of talking about noise/gain... How would you guys compare the noise between XHA1 and 301E? (The XHA1 is not known as a good low-light-performer).
2. Turning of the DRS and setting gain to -3db. Will this mean NO GAIN at all?
3. Doing the above - would you say that 301E will deliver a better low light capture than my XHA1 - all with lower noise/gain?
4. Okay... skewing then. Since I'm used to3CCD, I'm a bit afraid of this. But, I think that I might be able to avoid putting me in "skewing situations".
5. Yes... another possible camera is the Sony EX3. I like the fact that it has a bigger sensor. But the question is: HAS 301E BIGGER SKEWING PROBLEM than the EX3?
6. Finally... Does the 4:2:2 work on capture to P2?
7. Oh, one more... Has the 301E the possibility the flip the LCD/viewfinder? (For use with a 35mm-adapter)?
Very thankful for any help!
