How do YOU work with AVCHD?
seanmc
I've had an Odyssey 7Q ever since I purchased my FS700. I've used it 95% of the time I've worked with it. The past 3 times, included yesterday's shoot, I've tried to just use the native AVCHD files.
.MTS files don't have any audio on my Windows 7 machine. Not in Resovle, not in PremierePro, Quicktime. Nothing. However, there is audio there and if I transcode it with Media Encoder, or break out my MacbookPro and use AVCHD>MOV...then everything is fine.
What I don't understand is why is Media Encoder capable of reading the MTS files properly to transcode, but PremierePro cannot? I've tried everything listed on Adobe's site (using media browser instead of direct importing, etc) but to no avail.
So really, how do you people works with AVCHD files? There are a lot of cameras that use this format, so why is it so f*cking painful?
AVCHD is a nightmare.
Audio plays back differently on different camera brands too. It all varies.
Plus some cameras' AVCHD can create "digital snow" in your footage within some NLE's especially Premiere. It's freaky. It LOOKS like there is snow falling from the top left to the lower right in front of your subject. NIGHTMARE.
Although it means bigger files, I always just immediately transcode to DNxHD and be done with it. Never any problems then.
I.
Hate.
Compressed.
Codecs.
I use a Panasonic AC90 and FCPX and so far had no problems with AVCHD. Though for obvious reasons you would expect panasonic to be able to handle it.
What version of Premiere do you have? I think Premiere can play back AVCHD since CS5. I have CS6/Win7, and have no problem with FS700 AVCHD audio. Note that there are two audio modes on the FS700; MPEG and PCM. MPEG is standard for AVCHD, and some systems don't like PCM (although Premiere seems to handle it). Try keeping the folder structure intact when you copy footage off the SD card, and use Media Browser to import footage into Premiere.
I'm running CC 2015 on windows 7 pro.
I'll have to double check the audio setting I have on my FS700, I believe it's PCM.
When I'm bringing the files into PremierePro (using the media browser) I will sometimes get a message that I need a dolby codec and that premiere will install it on the fly, but I have no idea if that's working or not.
Just try transcoding a batch first, then bring it all in at once to a new project and just see what it's like.
While I would never imply that AVCHD in Premiere "doesn't work", everything you'll then do just flows just a good bit smoother from ProRes or DNxHD files.
I use AVCHD from my FS700 all the time in FCP X. Not painful at all, works just
great, fast as working with DV used to be if not faster (obviously capturing is faster
because you don't have to capture in real time from a tape.) I am not a CC user,
but I do remember, that when I used to use CS6, that it sometimes took what
seemed like FOREVER to draw the audio waveforms. Once that was done, it seemed
to work just fine with the AVCHD. But that first time bringing video into the project
was a royal PITA.
No problem playing back AVCHD files in PP for me.
Not sure about Windows, but with PP CC on a Mac I don't import the individual MTS files, but rather the whole "Private" root folder from the AVCHD SD card (which I have first copied to the hard drive) - leave the folder and its subfolder/files intact, do not alter it. Once imported to PP it will tell you it can't read some of the files, just ignore that message, then you will see all the MTS files within a folder called STREAM - I then usually re-organise the files into new bins and rename as I see fit.
PP will then automatically "conform" the audio from the files you've just imported, which you have to wait until complete before you can hear the audio (and see their waveforms) when playing back the files - look in the bottom-right corner of PP to see its progress.
Also if any of your recordings are longer than about 20 mins and span more than one MTS file, then you can delete all but the first MTS file in the spanned series from the bin in PP - this makes it easier to organise (you can tell if a video spans more than one MTS file by looking at the length - if some MTS files have exactly the same length as the one preceding it then it will be a spanned file).
I think that is the key point. With FCPX it imports the lot.
If you look at https://en.wikipedia.org/wiki/AVCHD#Overview
There is a folder for vendor specific information and other folders and files other than the MTS file. These probably are needed by the editor program.
Why don't you use the Sony software specifically designed to bring the files into the PC ? It will join the files together into clips with no loss of video or audio. Catalyst Browse http://www.sonycreativesoftware.com/catalystbrowse it is free and will also transcode to a number of formats too. I seem to remember that some version of NLE's only work with Dolby sound for AVCHD though.
You were correct Eric. When I changed my "HD Audio Format" from Dolby Digital to PCM, everything works fine now. Davinci, PremierePro. It's all good now.
Thanks!
Here is the most important thing you must remember about AVCHD files-- You MUST import the whole batch of them, in one file, at the same time. That means if your FS700 has a group of videos in one file, that entire file must be transferred in one go, into one file.
There are some operating systems that will allow you to import individual videos from an AVCHD batch file. DO NOT DO THIS. EVER. You will lose vital information about your video.
Like other respondents, I import AVCHD directly into FCPX on an iMac. It works perfectly. However, I can understand your frustration. If you are using a Mac, you can use QuickTime to convert the files. I used this with one file that had an audio problem, and it cleared it up quite well. Other than that, there are a number of other apps that can perform the conversion.
I am getting religious about deleting the older, already saved videos before I download them from the internal (SD card) storage. If I am not shooting a long commercial job, I'll usually keep the downloaded videos until I have new material to download. Then I'll go into the archived videos on my editing computer, and confirm what videos I have saved there that are still on the card. I will delete those from the camera, then download the new material.
Cumbersome, but it soothes my paranoid tendencies.
I've been working with AVCHD for over 3 years now, never had a singel audio problem in Premiere, both on Windows and Mac...
Import the footage over the media browser in Premiere.
If your clips are long enough then they span across multiple clips and you should copy the whole folder off the card (which keeps the file structure intact) to your machine. From premiere you don't import via File import or dragging clips to premiere, you use the media browser in premiere to import and it treats spanned clips as one, maintaining the structure and without the audio hiccup that will happen otherwise between clip breaks.
If your clips are short enough that thru don't span, then you can import them the other ways and even rename them and they will still work.
In CS5 I noticed my audio did not play back (even though it was there) in premiere from 1080 60p footage when the audio in the sony camera was recorded PCM. When I changed it to Dolby digital it worked fine. However in CS6 I did not have the audio issue.
