Jay Rodriguez
Coffee Member
I shot a quick interview in HD and need to down convert it to SD, how is it done? I'm using FCP.
Thanks !
Thanks !
coffee said:I shot a quick interview in HD and need to down convert it to SD, how is it done? I'm using FCP.
Thanks !![]()
jade8472 said:Downconvert in-camera.
coffee said:you know what guys, you're not making any sense to me.
Anyone have any time to detail me through down converting to SD?
Jeff N said:When you downconvert in camera, does it give the option of downconverting 4:3 or 16:9? Or just 16:9?
ncje said:Coffee, just do it in FCP. Cut up your clip to desired edit, then do a conversion output in compressor. Under I think Advanced conversion - Just select the desired output and done (well wait for the batch to finish).
jaegersing said:The alternative is to capture and edit HDV and then export to an SD format after editing. This will give you slightly better results.
For delivery on DVD, you would export to MPEG2 720x480 with widescreen aspect ratio. If this looks squeezed on a 4:3 TV, you need to set the DVD player to output as letterboxed video.
xray said:Coffee, what FCP version number is that ? I miss DVCPRO HD 720/P25.
coffee said:Thanks guys!
hey ncje,
I'm not sure which option to select. Below is a screenshot of all of the options that I can see, which one should I select?
Thanks !![]()
