DavidNJ
Carbonite Member
Other than the obvious difference of DVCProHD to P2 cards vs. AVCHD to SDHC I have compared the brochures.
Here is what I found.
Both cameras have the same lens, sensors, shoot-time operator assist functions. Both process a 1080p/60 image internally. Both output SD to their component output.
And they differ primarily in the recording. DVCPro allows recording variable frame rates in 720p mode. However, that appears to be electronic processing of the 1080p/60 image processing rather than a change in capture rate.
The HPX170 uses two P2 cards has a hot swap capability. The HMC150 uses one card without a hot swap.
The HPX170 has interval recording. The HMC150 doesn't. This is likely a limitation of the recording format.
The HPX170 can record 100Mb/sec or 40Mb/sec in 720p/24or 30, the HMC150 only 24Mb/sec. At 100Mb/sec in 720p/60 or 1080i/30 modes, the HPX170 is recording significantly more data. In 720p/24 or 30, the difference is much smaller and may even favor the AVCHD's more advanced algorithms.
The HPX170 DVCPro allows text memo.
The HPX170 DVCPro can record 4-channel audio but only has two external audio connectors.
The HPX170 DVCPro is recording 4:2:2 vs 4:2:0...significantly more color information.
The HPX170 has an HD-SDI output, the HMC-150 uses HDMI. However, recording to a PC the cost difference in the adapters is much smaller than the cost difference between the cameras and the functionality is equivalent. The HD-SDI offers a better connection in production environments and is compatible with production recording decks.
It would seem the big difference would be in the recorded image quality, especially with regards to color.. However, I can't find any recorded image quality comparisons.
Do you know of any?
Do you know of any?
