Chris Light
for some reason, HDVSplit jumps time when capturing with my A1, meaning, the time counter during capture will be counting up to16:44:06 while capturing (for instance), then it'll suddenly go to --:--:--, then start at 00:00:00, but it stops capture at that point. then i'll rewind the whole tape and try to recapture the entire tape, but it'll only capture the first part of the tape until the counter reaches 16:44:06 on this particular tape, when i know there is about 40 mins of footage on the tape.....is my A1 counter to blame?....do i have to reset something in my cam?
not sure if i explained this clearly enough.
this has happened with 2 tapes now, and only since i started using HDVSplit to capture....
any advice would be treasured
thank you,
Chris
thank you,
Chris
