Cosimo Bullo
Ralph, why is no one using AviSynth as you are? Is it just a technical fear?? Is it still worth it in your mind given the quality of the AVCHD patches available now?
Hi! My name is Santi. I´m from Spain and i´m new here. I have a GH2 and Ninja and i can´t use the avisynth with my videos. They always give me errors. Can somebody explain step by step the process to transform a Prores ninja video with Virtual Dub? I´m sorry buy i can´t understand why i can´t use the virtual dub and the avisynth. I made the steps of the first post but i can´t do nothing with my videos. The only thing that i can do is transform with the mpegstream clip. Thank you very much for all. Sorry for my english.
Hi! Thanks Ralph. My problem is that when i open the script of avisynth in virtual dub, always give an error. For example: Sintax error, or error in line 9. I´m tried to modify the code but stills the error. I´m in windows 7 64 bits, and i tried with avisynth 2.5 and 2.6. I don´t Know what can i do. Thanks again.
Hi Ralph!
The script says that qtinput.dll doesn´t load or uncompatibility. Thanks!
On the Ninja, make sure the input rate is 1080i60, and not 1080i59.94. Remember, the GH2 is putting out a true 60.00i signal, not the standard 59.94i.Ok! Thanks Ralph! One question more. I recorded 1080 50i in the ninja. I can´t record in 1080 60i, maybe this is the problem too i think. I don´t know.
To change the camera to NTSC, you must use the hack. If you haven't hacked the camera, then 1080 60i will not be available.Mmm... i can´t put the ninja or the camera in 1080 60i. I only can record in 1080 50i. What´s the camera configuration to record in 1080 60i in PAL versions?
@billhingeJust wondering why you would use video mode for astro pictures. Seems like you should shoot in still mode for the highest quality. And perhaps use the 40 frame burst mode for bright objects.
