One thing to note with recording UHD from the F55 is that the HDMI output always has the MLUT applied. In order to capture an S-Log signal off the F55 one needs to record via SDI. Due to the limit of a single SDI port on the Shogun, it is limited to recording from the F55 via HDMI, while the Odyssey7Q+ can record from either HDMI or SDI.
If you select an S-Log as the MLUT for the HDMI out on the F5/F55, I believe that this means that the viewfinder and everything else on the F55 will be forced into log viewing as well. This may not be satisfactory for the operator or others who need to see the image.
When I had a Shogun here for review, no issues that I noticed with SLog output.
My issues with the Shogun are not with input but with construction.
Ned Soltz
Curious how you calculated this.Why i have set my eyes on shogun instead of odyssey if definetily the price, price of media, format support and included accessories. similar set-up on adyssey is about twice as expensive as it is on shogun.
The FS7 can output UHD or 4K over HDMI without the extension back, but the Shogun can only record UHD. The Odyssey 7Q+ can record both, again, with no added expense Record Option.
