David Quinn Carder
As many of you probably know already, FCP's downscaling is essentially broken. It introduces jaggies, and the more drastic the scale difference, the worse it looks. I've gotten rid of the jaggies by downscaling with Handbrake before sending the file off to Compressor, but my 1080i footage, after being downscaled to SD, does not look as sharp as the footage does in the Viewer/Canvas in FCP when the Viewer/Canvas scales the content to fit the window.
For instance, if I downscale my footage to 25% size, and compare it to the original footage but with the Viewer/Canvas set to 25%, the original footage looks considerably sharper.
So my question is: will using a hardware scaler, like a Matrox MXO2 LE or a Kona card, output video that looks like the Viewer/Canvas at 25% looks? How much better will it look than using Handbrake or some other software scaler?
My client doesn't want to spend more money than we have to, and render/processing speed is not an issue, so they don't want to spend money just to speed things up. However, if the quality is significantly better than using software scalers, they will probably want to buy a Matrox MXO2 LE or a Kona card or something.
And if hardware is the way to go, what do you suggest? I'm using a Mac Pro.
