The setting he showed at about 9:19 I think is the exact opposite for what he wanted to have happen. He wanted the GH5 to respond rapidly to his changing views and the two settings are to refocus slowly and the second to stay on the initial focus position. Looks like that is exactly what it did. Maybe the problem is giving too much control rather than having the engineers just giving a couple of settings.
I'd like to see the Barry Green GH5 AF test to set this to rest.
If it turns out that this is indeed the case, tests are accurate, and a FW update doesn't correct sometime on the software side this is disappointing mostly in the advertising sense...
"As Max pointed out, if you do not record in camera, the AF is fast. Otherwise, horribly slow, and depends if you are recording or not. And... You aren't recording in camera like 95% people will do. So unfair test. Sorry...! And when you pretend it works well.. Eww.. Sorry, it hunts back and forth and it looks ugly. Even a 80D has a better AF lmao." I agree
You should watch the video that Ron linked to on top of this page.
This one -
That video is weird, he was in AFS mode the whole time as you can see in the upper right corner, rather than AFC.You should watch the video that Ron linked to on top of this page.
This one -
But even so, if this is the best case scenario, who would use this for anything mission critical?He recorded everything externally, because the focus works way faster and better when using an external recorder. It must have something to do with the processor having to write to the card or something vs. just transmitting the feed. BS test. Most shooting will be done in camera, and in addition the AF, was a major feature of the camera that was heavily promoted.
I'm not sure what you mean by "normal" but if you mean letting the camera pick from all-zones, it's noticeably worse.I have not seen any tests of the normal continuous auto focus. All the tests have been of the AF custom settings. These I feel are intended to be set for custom use so would be different for different scenarios. For the Photo menu there are several presets for example. Has anyone seen the GH5 performance with just the normal auto focus ?
If I'm reading the manual right, the continuous AF in motion picture mode is a menu setting only and overrides the button setting (see page 167 of the advanced manual). P 89 says AFF & AFC work same as AFS in "creative video mode". It was obvious the af was hunting throughout the test despite showing AFS on the monitor.That video is weird, he was in AFS mode the whole time as you can see in the upper right corner, rather than AFC.
I'm having pretty good luck with the auto focus and the 15mm f/1.7 on my stabilizer. The Auto ISO looks like it could be super useful. Here's a sample from this morning.
https://vimeo.com/212295198
password is test123
Cheers, Pete
Yes, as soon as a face comes in range it goes to that. I haven't tried it out in the woods or in a crowd to see how it works in different environments though. I think this might work well for doing don Juan steadicam shots where you simply can't rack focus going backwards on a gimbal.That looks pretty good to me. Did you say you had it in face detect mode?
