Greetings folks,
I had asked around here for an explanation about all the hub-bub relating to the GH3 not having a multi-aspect ratio sensor, even though it listed as having multiple aspect ratios. I got a few explanations, but none of them were any good. So I did some digging around the interwebs and I finally get it now, and I made a diagram! Unless I am wrong, then ignore everything!
First a simple explanation. It is as simple as this, a multi-aspect ratio sensor can give you multiple aspect ratios while keeping the same effective sensor size. This is the key part which seemed to elude people when trying to explain it to me. Sensor sizes are measured diagonally. The GH2, when choosing an aspect ratio, will always keep an effective sensor size of ~22mm, whereas with the GH3, only the 4:3 aspect ratio is ~22mm.
Here is a diagram I whipped up. As you can see, the effective size of the sensor for the GH3 is variable, but still quite acceptable. Hope this helps!
