Apparently, you need to learn that skew and rolling shutter are not the same.
The most funny is when today the 'video artists' are 'too good' for having the infamous jello on their work... Almost 100 years ago, Lartigue left the autochromes once he could have the color but not handle the motion like this:Please provide examples of 35mm motion picture camera film exhibiting jello or skew.
Nobody said they were.
Fair enough, I just put in a call to a guy I know who has owned a One since they came out with the first firmware fix. He's not complained once about the rolling shutter, at least to me. [snip]
[A]nyway, I'd like to point out that there are also CCD cameras with rolling shutter too. The Canon XL series has rolling shutter for one.
Yes I understand that is the common idea behind CCDs but that's unfortunately not true. Most CCDs use something that's similar to "global shutter" but not all. There are a number out there that do use a line scanning routine that is somewhat alike rolling shutter. It's more immune to wobble and skew though.
I believe this as much as I believe your assertion that rolling shutter can be fixed via a firmware update.
Well then you have a lot to learn.
skew is inherent in the architecture of both CMOS and CCD.
It may just be semantics but that's never really stopped a forum troll before has it?
I see one mention of CCDs being more immune to wobble and skew, but the conversation has so far been about rolling shutter. So when you quote me saying that I don't believe a firmware update can "fix" rolling shutter, and then in your response talk about skew exclusively, then you put forth the strong indication that you believe that rolling shutter = skew, do you not?
That's right, nobody said they were the same. We didn't have to because everyone else knows that they are the same.
First of all, everyone knowing something is a false statement in and of itself, because it's not possible. Second of all, you just got after me for pointing out that that rolling shutter and skew are not the same and now you're saying that everyone knows that they are the same.
So which is it? Does rolling shutter = skew or not?
Jello is just "skew" in very short motions in multiple directions. It's simply the change in pixel readout justification in comparison to those around it. Since CMOS reads pixel by pixel in line by line fashion similar to the way old tube cameras (and the inverse to how tube TVs display) then you can have the optical output of a line read look shortened or lengthened when the camera moves mid-line read. In short, that means that if the camera changes directions between pixels, the remaining pixel read on that line will look different. To the same effect, if your camera moves slow enough to avoid mid-line changes, then you could still get line to line changes in justification which will manifest as skew/wobble/jello.
Panning back and forth is slow enough that the pixel to pixel reads aren't completely messed up but you'll still get a small amount of extra blur. However you will still get line to line justification changes and your image will lean(skew)
Put the camera on a car and go down a gravel road and the camera will vibrate. Think of it is tiny pans in random directions which will interfere with the pixel to pixel reads in a line but not pan the image enough in any direction to manifest as a leaning image. This will end up as wobble/jello.
Then get a CCD camera or go into 3D animation. But then again they will find something wrong with that too!
The only thing wrong with CCD now is that "no shallow depth of field derf!"
Not entirely true. CCDs also exhibit vertical smear on overbright highlights. And, when going for smaller chips, CCDs just can't deliver the same pixel count with the same sensitivity and the same heat management that CMOS can. Which is why we're seeing a proliferation of CMOS in little-chip cameras, and not so much infiltration in the 2/3" range.The only thing wrong with CCD now is that "no shallow depth of field derf!"
