So, I took the dive and installed the firmware yesterday. Seems to be fine, no brick, and I'm breathing a sigh. Pretty easy. I had a quick question though, cuz I'm not sure if I'm doing something wrong in the FCP workflow. Let's see if I can explain...
I shot my footage using the 24P with ACVHD D settings (or the recommended C settings on the 3.36 firmware patch). Then, I copied the Private folder to my harddrive. Then I used FCP's Log and Transfer to bring the footage into a ProRes 422, 1920x1080 sequence, 24p sequence. However, when I then dragged my clip over, it asks me if I want to change the sequence settings to match my clip. Which is weird, since the footage seems to be 24P with the default audio on the GH1 of 48 mHz, which should match the FCP preferred audio. (I didn't change the audio settings on the firmware.)
When I then right-click on the clip and looked at the settings, I saw that each clip was still listed as "Upper" for the field dominance. So I changed them to None. (And I checked out the clips in Quicktime, using the inspector, and it shows a 23.98 frame rate.) My question is, should I need to do this? Am I just some bonehead, idiot FCP newbie, and I'm somehow missing an important step before the log and transfer, or during the firmware?
And on a completely unrelated note, I noticed this. When I viewed the clips separately in the quicktime player, with the inspector on in quicktime, the variable bitrate was high. I think the number sometimes shot up to 50, which is neat, since I was only using a Class 4 PNY 8 GB card to test. However, when I right-click the clips in FCP and checked the settings, I noticed that the bitrate was listed at around 9. Which was weird... BUT... When I then tested out the footage (low-light, ISO 400, 50mm lens at 1.4, shutter 60) in Magic Bullet, the footage help up RIDICULOUSLY WELL. I mean, it was retarded how well it held up. The old GH1 could only hold up to color correction for up to a point -- too much and it stared breaking up -- but I really pushed it last night, and it held well. Perhaps, it's a placebo effect, but it seems to be working just dandy. I hope to do some "out in the real world" tests today -- mostly the Class 4 card will not work -- but I gotta try!
Anyway, back to the log and transfer? Upper? Should I change? Am I missing something? Or has this already been answered in another post, cuz I did a search, but couldn't find it. Thanks.
