Barry_Green
Moderator
After the Billups/ToNi shooting session, I decided I needed a better way to test for definitive dynamic range.
Enter the Stouffer 41-step transmission wedge, which is a calibrated strip designed to transmit light in calibrated 1/3-stop increments. Each step on the wedge is 1/3-stop denser than the step that came before it. So, every three steps = 1 stop. To calculate a camera's total dynamic range, you shoot the chart in front of a bright light source, and examine the steps to see where you can clearly distinguish between them, and wherever you can't, you take note of that step as the point where the dynamic range of the chart has now exceeded the camera's ability to resolve it. Whatever the number is, divide by three and that's the # of stops of dynamic range you're looking at (so, if it discerns 22 but not 23, you'd stop at 22, divide by 3, and end up with 7 1/3 stops of total dynamic range).
Much more repeatable than my prior test, and certainly less subjective in evaluation.
So -- I ran the GH1 in every gamma mode, using contrast -2 to extend the dynamic range as far as possible. I also did one test with Intelligent Exposure On Max vs. Off, and one test where I ran the standard gamma curve through many of the ISO settings to see how dynamic range might change under higher ISOs.
In all these tests exposure was set so that the first step on the chart, step 1, the most translucent, was rendering on the waveform monitor as just barely darker than full clipped white.
So -- here are the results:
Judge for yourself where you think the resolvable dynamic range ends.
As for my picks, I say that Smooth and Nostalgic definitely show more easily-discernible range than some of the others; at first glance it looks like "smooth" is 7 1/3, nostalgic is 7 2/3. But the fun thing is, the range really isn't changing any; the minimum and maximum are pretty much the same across all the gamma curves. They all pretty much max out at stop 25, if you pull them into photoshop and jack the exposure up so it's easier to tell. Vibrant seems short, it seems to actually cut off at about 23, and Nature's last discernible is 24, but Smooth and Standard hit 25. So that means we're looking at an absolute maximum of 8 1/3 stops in the best case, and 7 2/3 in the worst case, so not a lot of difference in maximum range. In just out-of-the-camera looks, yes, there's a big difference, Dynamic and Vibrant will give off a contrastier-appearing image, and Smooth and Nostalgic are flatter curves, but overall about the same amount of detail is still there and recoverable in post if need arises.
Higher ISOs do compromise the latitude a bit, at 400 ISO it loses maybe 1/3 stop as compared to at 100 ISO; at 800 and 1600 ISO I'd say it's about a stop down.
Intelligent Exposure (on level 3, maximum) definitely gives a boost to the shadows, but again I don't think it gives a true measurable increase in actual dynamic range; maybe 1/3 of a stop but that's about it.
