GH1 firmware research volunteers required
Unfortunately GH1 update is quite slow process.
So, it'll be best to write small firmware portion to change values using file on SD card.
Unfortunately we don't have assembler available.
So, our next target to obtain must be Panasonic C compiler and assembler.
I apologize if this has been addressed, but I couldn't find any mention of it in my search. I've updated my firmware to the native 24p hack, and when I try to play back in camera, it doesn't freeze. Actually, I just get a message saying "this motion image cannot be played." I then tap the shutter, then go back to shooting like normal!
Just an observation on my part, since I noticed most people saying that the camera would freeze and require a battery pull.
PTool 3.30 updated without version change.
Main change is AVCHD Compression patch, using test results this patch is targeted towards allowing better behaviour while increasing bitrate using other patches.
Note - this patch is untested, as I don't have time to test it carefully (I added it to public version to save us some time), but it is based on test results of other internal patches.
Note to testers updated on first page.
Tester just wondering, are you working on hacking the auto gain feature of the GH1? Just wanna know if i have to invest in a decent recorder.
You need to test it without PAL->NTSC patch. And get real NTSC camera for test.
One of the reasons can be audio level error or similar things. Your explosion can cause some hardware error.
It's not a noise issue as there is almost no sound (fast conflagrations, not explosions.)
I can't simply get a real NTSC camera...
But what I was shooting was often very complicated,
...and I did have some AVCHD bitrate changes besides the PAL>NTSC hack and I thought I might have broken the codec with the complexity. I'll try without your hacked firmware later.
Remove all other stuff, use only PAL to NTSC.
May be you are having some interference or SD card have issues.
Your problems are not related to PAL->NTSC hack.
http://www.dvxuser.com/V6/search.php?searchid=5640570 should bring up many of the previous discussions in this thread on the subject (or search the thread for "limiter").
At risk if going over the old ground again, if you disable the GH1 limiter, then instead of limited audio you'll get distorted audio. To avoid that, you need some kind of level control in the displays, with associated metering, etc etc, and the chances of even the highly gifted Tester13 coming up with that anytime soon are somewhat - er - limited, IMHO.
Unless you are just doing family stuff, you are likely to need a decent recorder anyway.
I made small research and we have some parts already implemented - we can use playback audio level as control to set our level and we also have necessary small icons that can be taken from audio dubbing screen.
New testing results.
Bad news.
I tried AVCHD compression patch with VB-33.500,MaxB-24.000,AltB-22.000.
It freezes camera.
With all parameters at defauls, no freezing with this patch.
So, this needs more work.
Good news.
Shot some MJPEG test footage using quality = 256.
Amazingly looking 57,5MBit result (bitrate is 2x from original).
Such bitrate is archived on high detail scenes.
No problems so far, but high speed card is required!
Bad news.
It freezes camera.
Good news.
Jesus Christ! 57,5mbit!!! That is incredible! Is this in full hd? Can we see some samples?
Please, try to read before posting!
This is MJPEG 1280x720p30.
As for example footage - I don't have time for this, sorry.
Ask testers.
Plus we are on too high level, as quality setting behaviour is quite weird.
For example 256 works, but 384 (another 50% increase) show that maximum clip length is decreased accordingly, but actual bitrate is back to about 27Mbit.
Good news.
OMG! That's... that's... I've no words! :shocked:
Bitrate peaks are at about 62-63Mbits/s (grass, leaves, etc), I also don't see frame skipping.
But anyway MJPEG requires much more work to understand encoder in more detail.
Ask testers.
ç
When I asked for example footage I was not asking you specifically...just anyone.
1280*720p at this bitrate should be fantastic...if it could be 24p o 25p instead of 30 it would be even more. Great work, guys!!
Are you able to playback the video on camera or it freezes?
I did not made many tests.
For few one I got "Read error. Check the card."
I believe camera make check for bitrate.
As low detail scene with same settings plays fine.
On computer all files play fine.
If these elevated MJPEG bitrates can eventually be used at 24-25 fps (without frame skipping) it would be so satisfying! And if it were also possible to change MJPEG frame to size to 1080 it would make it even more usable. Very encouraging, thanks.
