GH1 firmware research volunteers required
Looks like a good (working) condition TZ5 is available on Ebay for $130.
Does not leave much for shipping, but I am willing to cover the shortage.
Do you know how much do you need to ship this stuff to Tester13?
Lets first ship first batch. I gave all instructions.
Later, if funds will be enougth go for TZ5.
It is not much hurry, as even MJPEG engine is not entirely the same on TZ5.
I plan to use it for compression experiments and for screen graphic drwaing experiments (this is very similar considering same screens used).
But this also requires large amount of reversing work to be done.
Btw. Very useful thing will be to have some utility to display icons, pictures and fonts inside firmware. If you have good C knowledge you can contact me using PM for details.
Tester,just how much difference will having the GH1 body mean to the hack and the progress you can make?
Thanks again for all your work so far and if you need more funds for things please post,my paypal finger is still willing.
Here's my effort with a PAL camera, no hack.
http://dl.dropbox.com/u/3241184/GH1res.zip
Sami
Thanks.
So we have same exactly FOV (unless you adjusted it during shooting).
But simple scaling is very noticeable on short clips.
Try to shoot 1080p using native patch.
May be even PAL->NTSC+native.
So you could also shoot 720p60 in same conditions :-)
Important addition - try to shoot photo of max resolution in 4:3, etc, keeping same camera position and zoom, so we can know how 16:9 is cropped from the sensor.
Tester, would it be possible to offer alternate aspect ratios for video capture like with stills mode? Would love to have a native 2.35:1 mode and also 1.33:1 (and I guess 1.66:1 if the other two are easily doable). Thanks again for all the hard work and I apologize in advance if this was already covered somewhere in the last 32 pages.
Not that I have any saying in this, but if it were up to me, I would rather see Tester13 focus on getting higher bitrate 24fps video in all three video modes (1080p and 720p AVCHD, 720p MJPEG). To me, that gets the highest priority.
It is hard to say.
We'll just have more low level experiments.
May be they'll help to get some results in our areas of interest.
I think it is easy for Panasonic, but very hard for us.
Due to fact that too much constants are hardcoded for 1980 and 720.
If shooting at 2.35:1 ratio is possible, let's say GH1 only needs to process 1920x820 image instead of 1920x1080, would it free up GH1 cpu resource to process images better? just speculating...
You already can adjust bitrate (and I really need tests with lower settings - see my previous posts for complete explanations!).
But encoder also have parameters for I and P frames, so adjusting bitrate up do not lead to quality improvement.
Thanks.
Camera was fixed on the tripod between each shot, no adjustments made whatsoever.
Sorry, I need my camera daily for very important shots for the coming weeks and I don't want to do the patch just to be 100% safe. Maybe someone else can go on from here?
I can do the max resolution shots tomorrow if no one else does it by then.
Sami
Keep in mind that the GH1's 4:3 does not use the full sensor it is also a crop....the full sensor is larger than the image circle the lenses produce in the corners. This is so in 16:9 it can actually get a little wider and lose less resolution. There is no picture setting on the GH1 that uses those far corners of the sensor.
I know. We just want to find crop positions.
Is there a lens we should be using for this? Ideally a 50mm because it would have no distortion?
Bumkicho: "If shooting at 2.35:1 ratio is possible, let's say GH1 only needs to process 1920x820 image instead of 1920x1080" -- actually, even 2K CinemaScope (2048 x 858) is a smaller area than full HD (1920 x 1080). I would love that to be possible with this little camera. Interesting idea that using just less than FH pixel area might help image quality even more (when combined with increased bitrate and AVCHD optmisation). Even if the codec is improved with the GH2, it's unlikely they will offer an enthusiast ratio like 2k CinemaScope -- this sort of unique possibility (among other things) would extend the useful life of the GH1 mod even after the GH2 is out.
And while we're on about changing frame shapes, earlier I wondered if it could be possible to set the region of interest to be a 1:1 area on the sensor (so no sensor downsampling), again, maybe in CinemaScope ratio, which would be useful for C-mount lens users because of the smaller image circle?
Cheers, inspiring thread...
