GH1 firmware research volunteers required
In no way he could see if this is hot, as only LSI chip can be hot and it is not connected to any heat spreader to feel it.
And I do not believe in problems by upping bitrate by even 50%.
Normally such chips have big reserve.
And it won't be damaged anyway, just could show glitches like overheated processor. And as EEPROM is on another chip (contrary to Digic) it is quite safe.
you're right, with no heat speader its unlikely to see a heat difference. but 50% more... dunno if the safeties are that big, nowadays they (electronic market in general) tend to make it as cheap as possible (and we get what pana paid for :tongue:)
if you have enough knowledge to make such a guess that must be good enough (or at least wont get any better ;))
Such panning always make image very bad.
Mud issue can be related to P frames number (and their average size, of course).
They made 1080 to have slightly more bitrate (not enought) and reduced number of P frames. So, we have mud as result.
wait a moment: they don't use B frames & i thought thats the bigest problem with the GH1, that they have to strech the I frames. do you have the chance to increase the number of P frames even more (resulting in slightly better IQ)?
Such cameras are made with sufficient reserve, to make them function with +35-40C outdoot temperature. It won't be worse at 20C and high bitrate.
Anyway it is pointless talk. As we have Canon cameras that are hot like cakes and they haave high temperatures of LSI chips with RAM and EEPROM inside. And they still work.
Definitely you'll see many many glitches before dome real problems can occur.
I believe that we can play with P frames in some range.
1280 have about 7 P frames ?
Wow this is getting better everyday, keep up the good work Tester13, i'll be donating a bit more this thursday.
Oh man; this thread is a wonderful reading, i hope make donation soon enough but from my country is a really difficult thing to do, believe or not (i´m from Venezuela) but for now a encourage note for Tester13 and Chibs, thank for your efforts friends.
P.D: Sorry for my bad english
Another way to improve AVCHD IQ, might be decreasing fps in 720p mode.
If I'm not wrong, 25fps instead of 50fps means more bits for less frames. Even without increasing bitrate, IQ should be better.
Hey, it's tester13, not me. ;)
I'm afraid I don't see much improvement with the second bitrate setting, and it also doesn't allow me to go above the 20mbps on the first bitrate setting. For now I'll stop playing with it, and let's just hope the donations fill up quickly now so that we can buy a GH1 for testing.
I'm already very happy the 30 minute limit has been removed.
I have donated another 5$. It's not much, but every dollar helps. So if you can spare at least a dollar, anyone, that'll be of great help. You can donate at http://www.gh1-hack.info/.
Congratulating for you tester13
Firmware working and gone time limit on PAL version.
I make donation soon too. (10$ DONE) but I think I will make it again for progress ;) good luck tester13!
Regards
NURBS
To be honest, this IS the worst mud I have ever seen with my camera. Since I now reverted back to the original bitrate, I'll try it again doing a close-to-the-original clip later.
Please do, Ive never seen anything like this and I have tested and done similar whip pans in the same conditions.
It's important to know that the hack doesn't have a negative effect after all.
sami
If you look at patches list we have same thing for 59,94.
It don't work yet, as more work must be done before we could understand that is wrong.
It can have any effect. But this is not permanent, any time you can go back.
And we still do not have tests with low bitrates set. And this is importandt thing.
Like 8.000.000 and 12.000.000 and reverse for both bitrates.
We need to understand how it work.
sami
Well, I uploaded a clip with the original bitrate settings:
http://www.megaupload.com/?d=A2ST15NO
It looks less, but it's still present. This could be due to a large number of differences though, so there's no reason to blame this on the patch.
Also, this is not with the kitlens, but a C-mount lens.
