GH1 firmware research volunteers required
Isn't 40mpbs just out of it's league hardware-wise? I'd try a small increase first.
You are correct.
It is best to use about 11.000.000 to see if it works.
And next up to 18.000.000 - 18.700.000.
I also need all details about 1080, and all 720p modes. I, P frames, average sizes, all that.
the version change works, but I changed on one test only the bitrate to 40mbps and after beginning to record the camera freezes, even the off switch, had to remove battery to switch off. fortunatelly it only happens after hit record, so I reinstalled the firmware.
Either hardware are not capable or we just see some buffer overrun.
Buffer sizes can be adjusted to maximum 16Mbps.
Well, sadly the 30m limit is not removed. It functions exactly the same as before.
Next up I tried to change the bitrate to 18mbps, and the camera does not freeze. I am however unsure how to check if it has actual effect on video, how do I see the exact bitrate of a video? (Pardon the n00b question here, I'm unfamiliar with AVCHD)
AVCHD can't go up beyond 24mbps so don't even bother to try above that.
It's worth trying, just because the spec doesn't officially support it doesn't mean the camera won't write it, even if you need some tricks to decode it at the PC.
I updated Ptool 3.0, this only concerns 30min limit patch.
It was nasty bug in patching engine, wrong branch instruction patching branch instruction (always check extreme cases, good mathematicial statement). :-)
May be they just love each other.
All must work now.
Redownload PTool please. It have fixed patch for 30min limit.
Ask guys here about software tools that show verious parameters. I also need such tools on personal testing stage.
We can also play with I and P frame ration.
Have you updated the front page? I redownloaded but the version number of Ptool is still 3.00. I know its a small thing, but it's more manageable for me if there's a difference in the numbers so I know. :)
I have currently used a firmware with bitrate upped to 19Mpbs, which seems to work fine. I've downloaded a program c alled MediaInfo, but it says 14.6Mbps.
I will now try the new 30m limit remover.
Also tested 60p->24p, unfortunately it does not work:
the video is 23.97 fps , correct, but the file video structure appears messed, only 1 I frame and the rest all P frames, and it records to 12fps if shutter is 1/60 or less and 6 fps is shutter is over 1/60.
It also must be expected. Some other things must be changed here for correct work.
Try to test if wrapper patch work (most probably we'll also have some glitches here).
Is that checking the original MTS file?
I uploaded new zip file :-)
Yes, version is the same. Because only small bug is fixed.
As something will be added, we'll change version number.
@Chibs: so you found mediainfo yourself :-)
check for the overall bitrate from the general section, thats reported as 18max at the moment
I want to repeat again - try to lower bitrate setting, not upping.
At current stage we must understand how it work.
And shoot some highly detailed things to get max possible bitrate.
Where can I see this? I only see the First Video Streem information.
Yes, I understand. :) I was just curious.
I have some very very good news: The 30 minute limit seems to have been removed. It proudly says in the corner of my screen that 1 hour and 47 minutes remain for recording, instead of the usual 29 minutes and 59 seconds. I will soon try to film more then thirty minutes to see if it truely works. If it does, you are the greatest!
This pleases me so so much, and all PAL owners alike.
Wow. Nice work, tester13 and Chibs. If we can confirm that third party battery support works (or that it's possible to revert a version of firmware that works) I'll be able to do some testing myself...
in the menu view select the entry tree & you'll see more infos :-)
that would be great news if got rid of that nuisance (got to thank the EU first for getting us that stupid limit)
