wanderer63
My Epson projector via the PS3 says interlaced also.....1125i.hi tester13
here is some minor problem with native 25p footage
final cut interpret it as interlaced - upper field first
thanks
Strange.
thanks
PTool 3.36d released (development version for testing only)
http://www.pentax-hack.info/firmware/pan/ptool3d.zip
Added Version compare patch.
Short description: You need to set version increment as usual first time then using this patch. But since next upgrade you can omit increment at all, and leave this patch only.
This is risky patch, as can make body non-upgradable. Probability of this is very low. Bit it can happen, as it is untested patch. So, one brave tester is required.
hi tester13
thanks
Can you add the ability to load lower versions, such as the original Panasonic releases?
hi,
This would then mean I can do 15 updates and still be able to revert to v1.32 original firmware if needed for warranty?
thanks.
so the latest untested Ptools 3.36d will let you update anytime to original 1.32 firmware and it will show as v1.32 on camera? If so that's brilliant!
thanks
tester13, my question to you is -- is there any way you can optimize the bandwidth to prioritize the I-frame? I had one clip which had really bad "pulsing" -- too much detail for the I-frame, so every half-second it would "glitch" for a frame or two while the rest of the GoP "caught up".
I think that especially with the higher bitrates for the overall GoP that are being achieved, that we could really see some benefits from allocating more bandwidth to the I-frame so that the I-frames are cleaner. Is that possible?
Ozpeter, do you feel there are big improvements from native 25p over original 50iwrapper, as a PAL user? or is it removing a step in your workflow?
I guess having gone back to the original firmware, which would have the ability to go back to earlier versions not permitted, I couldn't now go back to an even earlier official version without first using ptool again to change the firmware to permit that? So if anyone wanted (for some reason) to go back to pre-1.3, you'd have to use 3.36d to only remove the version comparison feature, then after that, go back to the earlier firmware. Or load that earlier firmware into ptool with nothing ticked except the new 'remove version comparison' box. I suspect a crystal clear FAQ entry is required on this else there will be loads of questions.
This doesn't make any sense to me. At all.For keyframe pulsing, you usually want lower bitrate allocation to the I-frame, and higher to P-frames. ie. you want to lower the Iratio (and lower the P:B ratio if it was using B-frames) . By having a lower ratio, the quality difference between P=>I frame transition is less, everything looks more even to the naked eye, and there is not as much as a quality jump.
The i-frame is clearly nowhere up to the task of properly representing the image. As you look at the footage, it's obvious that the I-frame starts out mushy and blocky, then the first P-frame improves on it significantly, then the next P-frame brings it up to standard, and it stays that way throughout the GoP. Then, at the start of the next GoP, SLAM -- there's a huge quality drop as the inadequate I-frame starts the cycle over again.
Whereas if more was allocated to the I-frame, it'd look better in the first place, and you wouldn't need as much bandwidth allocated to the P-frames because they wouldn't have to work as hard to bring the bad I-frame up to snuff.
I need sample of native 25p footage.
