you can monitor the sound through the zoom. it has a headphone jack and a line out.
..You are talking about the GH1, right ? I didn't not see anything like headphone jack on it. Where did you saw that ?
No we're not on the same page:happy:! I had suggested that the Zoom could be used in place of a radio mic in certain situations and therefore the idea of a sound man desperately checking levels whilst being trailed behind the actor/interviewee came to mind.I'm not sure we're on the same page. You want to attach the H4n/H4 to the talent?
but if you have no budget attaching a H2 to the talent could be an option. You'd have to check levels before and after the shot but you wouldn't have to worry about rf interference. Olympus make an even smaller recorder and there are some others. I think I'm gonna forget wireless altogether and try this instead
Yes you can. The only problem is that, in this situation, the on camera talent would have to have a sound man permanently attached to them, which could be a real problem for the script writers.
Screw them. Have you noticed that in any movie-about-movies which feature a sound guy, they ALWAYS die/get fired first? I was so pissed off when I went to see King Kong.
One problem with (Zoom Hxx) is, that using it with external mics tends to cause a bit of background hiss, which I've not been able to remove. If you search around it's well documented for this recorder.
When the audio is being recorded on the talent you aren't monitoring it. So that is a risk many production environments won't accept.
If the hiss is consistent, it's relatively easy to remove it in post, using noise fingerprint reduction in a tool like Adobe Audition. Be careful not to overdo it though, or you'll get something that sounds like it was recorded inside a bathtub.
