dpc said:The HVX is servo driven, but it's repeatable. I've marked the barrel with tape for rack focusing. It also doesn't matter how fast or slow the focus ring is turned -- as long as I hit the mark, focus is spot on. I wish other companies would have this feature.
What do you mean by repeatable? I'm pretty sure I read the XH-A1's focus is repeatable, though I'm not entirely clear on what that means.
Even better, you can program the focus ring to have a slower response when turning it so that you can accurately and easily stop on a number from the distance readout meter, which is very accurate. (in meters or feet)
The A1 also has a focus preset feature where you push a button and it will repeat a focus pull to the same distance readout number, and at three different speeds.
It's pretty easy to do repeatable, accurate focus pulls now.
What is meant by "repeatable" focus and "repeatable" zoom?WHAT DO YOU MEAN BY TRUE?
Yes you can manually focus, zoom and change the iris. If you mean is it a true lens, then no it is not, it is servo driven so no repeatable focusing.
If I am not mistaken I believe that DVX and HVX are servo driven as well.
Repeatable means that as you turn the focus ring to a certain position, the internal focus distance in the lens is set to a certain distance, and that you can repeat that over and over. Servo lenses are typically not repeatable; in servo lenses there's a motor driving the focus position and the focus ring is actually more of a "motor switch" than it is a focus position setter. As you turn the ring, the internal lens motor gets turned to "on", when you stop turning the ring the focus motor stops. But the amount that you've turned the ring, and the distance that the focus elements in the lens moved, don't necessarily have any relationship at all.
