Fisheye newb question
Halfcan
I want to purchase a fisheye for 7D but am not sure what to get. I have looked into the canon 15mm 2.8 , sigma 10mm 2.8 and the tokina 10-17 3.5-4.5. Please give your thoughts on the pros and cons of each lens. I will mostly be shooting video with this lens and want to use it for some cool looking shots.
Also, is there an expanded focus button on the 7d that I can use with the primes to check focus?
thanks.
On the 7D there's a 5x and 10x zoom you can use on the LCD to check focus.
15mm on a cropped sensor probably won't give you the fisheye look you're going for. It's definitely wide but not what I would call 'fisheye'.
Should I look into the sigma 10mm because it is a little wider than canon 15mm? I plan on moving up to the 5d in a year and the canon is the safest bet because that will work on the full frame cameras and sigma will not.
sigma 10mm is awesome and tack sharp.
for standard processing, lately i'm using lightroom. i like the tools and being able to quickly edit a ton of photos is priceless. for hdr stuff and more intense editing, i go to photoshop.
of course the secret to colors that pop is starting with a properly exposed image. the more info you have in there, the more you can do with it in post.
