The audio sounded like you had some audio rate problems... did you have it set to 44.1 or 48?
Some nice shots in there![]()
There are major audio problems with this video, the music pops throughout. And yes the bird is annoying.
Its hard to comment on exposures on a Vimeo video but much of this seems a bit overexposed, it also depends on which picture profile you were using, chroma [saturation] seemed a bit much.
As a rule of thumb your pans should take at least 7 second for an object to get from one side of the frame to the other. Its not so bad on an online video but if you projected this or displayed it on a large progressive monitor it would strobe quite a bit.
the popping is probably the result of using an mp3 file. The song you used was an mp3? If so, next time convert to AIFF in itunes.
Yeah someone told me that earlier, I think there's a way to convert it in FCP too.
Yea, just right-click the file in FCP --> Export --> Using Quicktime Conversion --> select AIFF.
