Chris Johnston
Since the firmware update will be coming out in a couple days I thought I'd make a post and try to keep issues, anomolies, workarounds in one new place. I would like to get both the good and the bad, plus how you overcome the bad (if there is any?) I personally am very interested in the 4, 8 x enhanced focus, PP saving/naming and also performance with the LA-ea2 adapter/ a mount lens' combo but others may find some of the other features exciting.
Soooo.
1) any installation problems? (did it go as planned? was it as easy as they said? Did it blow away your special PP3 back to the stock PP profiles?)
2) LA-EA2 problems? (Does the a mount glass work correctly? AF? iris? etc)
3) Can you name your PPs? (I really want to be able to name them in the menu..... (5DmII, outside Hi lite, etc.... NOT PP1, PP2 etc)
4) Can you pick which features you want installed? (I don't personally need PAL stuff, can I update without installing certain features?)
5) Any anomolies? (when you pull the battery or format the SD card, did something go away? etc)
Just a place to keep all the info in the same area..... Maybe even a sticky?
Thoughts?
update avialable here (around April 19th or so...)
FS100 Software Update here
Soooo.
Thoughts?
