This a double post, I am new and did not notice the sub forum specific to the A1, sorry.
What is the advantage of using a Firestore with an XH-A1?
Is there less compression by avoiding going to Tape and going right to hard drive?
If the only advantage is that you don't have to use your A1 for play back wouldn't it work just to get an HV20 as a deck rather than spend the money on a Firestore you would now have two HD cameras and essentially the same ability to not run down the heads on your A1.
Is an HV20 able to function as a deck for A1 footage or is there a problem with the 24f function of the A1 being played back on the HV20?
Right now I see the only benefits of a Firestore as:
-More recoding time
-No capturing time
-Preservation of the A1 heads
Anyone have some insight?
-More recoding time
-No capturing time
