The trick I see with any option though, is keeping the filter/filter holder out of the image. This lens in particular is a tough one to do that with.
105mm filter!!! How much is that?
Use step-up rings to make an adapter to slide over the lens shade from the back of the lens:
Start with a 72-77 mm. Have the lens off the camera and slide the step up ring over the lens until it grips tightly over the lens shade. Then add a 77-82mm, a 82-95mm and a 95-105mm. Then a 105mm filter will screw on and press against the lens shade. This will help keep the assembly in place. This should give you about 3mm filter depth until it vignettes in 16x9 mode. I'll have a slim mount ND filter in a few days to test with and I'll let you know what happens.
I had originally tried it with a 95mm standard filter and it would vignette at between 8 and 9mm.
