On the GH1, AVCHD file spanning across multiple 4GB MTS files is a rather fragile mechanism that doesn't appear to work reliably at bitrates over 28Mbps. If you check out the patches linked in my signature, I've set the 720p "H" mode to the highest bitrate that worked with file spanning for each patch. Unfortunately, there is no comparable way to select a lower bitrate 1080p patch on the GH1.
