Okay, here's the deal. I want to know how fast I can possibly get the data off of my P2 cards and onto a hard disk. Unlike most other peoples' posts I have read on this forum, I will most likely be using a workstation tower (a mac pro), and not a laptop. Currently I have one of Panasonic's AJ-PCD20 readers and its speed is a continual disappointment. Don't even get me started about price to performance ratios. In the studio and in the field, I get around 15MB(megabytes)/s transfer off. This is pitiful and because P2 cards are ungodly expensive it's slowing production down. So:
A) I want to know if anyone is getting better than 8-9min for an 8gb card and/or double that for a 16. If you are what are you using (I think it's usually Macbook Pro with an expresscard splitter, a PC Card to expresscard adapter, and some fast hard drive solution).
B) How fast is the transfer speed off of P2 Cards really? 8gb cards are spec'ed at 640mbits/sec (so like 80mbytes/sec).. I'm getting a max of like 23mbytes on my buddy's powerbook g4 and I just know it has to be a lot faster.
C) Does anyone have any reccomendations about PC Card to PCI Express adapters? I can find PC Card to PCI, and then a big four slot PCI to PCI Express, which is cool and attractive because it's gotta be faster than the PCD20 and it's a heck of a lot cheaper (totals about $500ish). Basically anything over FW800 since I'd like to be able to dump two at full speed because..
D) What do people reccomend for a portable RAID10 setup? I think I'm probably going to do a 4 drive RAID10 solution so I can make use of the mirrored drives as pseudo-backups (since I can put them in another RAID 10 if my original two die in a fire and see all my original data, right?). Since the Addonics portable towers with hardware port multipliers will hold a max of 5 drives and are about $250, I think 4 is kind of the sweet spot for me, which in RAID 10 puts me at a write speed of about 120Mbytes/sec with..
E) What SATA drives do people reccomend in about the 60mbyte/sec write range? And has anyone used those Western Digital Raptors for more than a couple of months? Are they at all reliable? I think they're the fastest SATA drives on market still?
F) What is the speed difference between the esata off of the computer motherboard and using like a sonnet tempo or whatever? I would like to not have to buy a dedicated ESATA controller to run my RAID if at all possible. Also if there's an Addonics-like portable and cheap RAID box with port multiplier solution that runs on Fibre Channel that works too. Most Fibre stuff is way expensive though. And SCSI ultra 320 isn't an option, and really neither is SAS, since that's mad expensive too. Under a grand is the key.
Here are my times so far just in case anyone else is wondering how different hardware changes things:
From PCD20 over FW800 to Lacie Quad interface d2 on FW800 on separate bus: 15Mbyte/sec so like 8-9 min for an 8gb P2 card.
From PCD20 over FW800 to big ol XSAN capable of above 160Mbyte/sec sustained write (as in I've captured uncompressed 10 bit 1080i HD in the studio to it with no real problems before) on dual Fibre Channel: 20Mbyte/sec so like 6-7min for an 8gb P2 card.
From powerbook G4 PC card slot to OWC 250gb quad interface hard drive on FW800: 15-23Mbyte/sec so like 6:40 for an 8gb card.
Thanks all. Am I the only one that bought this reader? What did you all know that I didn't..
