Since I add FX and many transitions the general rule of thumb is to convert to Pro Res.
I work directly with the native H.264 files.
Transcoding time = 0 !!
I still don't get why this is better for image quality. I'd love for someone to make a side by side.
When you start to do fancy things to the footage it breaks up and makes weird artifacts in its native form.
Perhaps I ought to do a definitive test.
This is the part I don't understand how an intermediate codec can alleviate. Artifacts just don't go away when you transcode it.
Well I guess that's a no..... Since I add FX and many transitions the general rule of thumb is to convert to Pro Res. Thank you people for the replies.
It seems to me there could be 2 benefits to transcoding to ProRES:
First off, as people have mentioned, ProRes is a more CPU-friendly codec, less work for the CPU means quicker effects
Secondly, transcoding will never create data where it didn't exist before, but color correcting, for example, in a broader, less compressed color space and codec should allow you to make greater adjustments without all of the added artifacting of repeated 264 compression steps. I agree that a test would make all of this more clear.
...but color correcting, for example, in a broader, less compressed color space and codec should allow you to make greater adjustments without all of the added artifacting of repeated 264 compression steps. I agree that a test would make all of this more clear.
Most of the frames right from the camera are guesses, so when you tell your computer to guess what two guesses would look like if they were mixed together there is a lot of room for error, and that's where new stuff creeps in.
When you put it to prorez, your taking a snapshot of the guessing frames, so its better to mix those then to mix guesses.
Its like if you had 2 photos, one with a man on the left side and one with a girl on the right side, and someone asks you to draw what would it look like if they were combined in the middle?
Now you have an apple on the left and photo of an orange on the right. And they ask you what would it look like if you combined those in the middle.
Now here is where they tricky part comes in, they ask you to combine both the man/woman and apple/orange pictures, with just looking at the 4 original pictures and not at the combined pictures.
So you take your wild guess and there is room for you to be so wrong.
Converting to prorez keeps the picture of what they look combined, so it has a better shot and combining more mutant pictures.
So its not about artifacts going away, its about not bringing new ones in.
