It looks like I'll have to invest thousands of dollars in an external recorder
Video Devices PIX-E5H : $1,195
Atomos Ninja Assassin : $1,295
...It's something that I had planned to buy anyway.
The wildcard is Black Magic. An Ursa Mini for $3K is pretty cost competitive with the GH4 and an external recorder. If I was starting fresh, I'd have a hard time picking my GH4 again.Yup! Not thousands, just a thousand.And truthfully, if I had to choose between $1,200 on ProRes 422 HQ 10-bit footage from my existing camera, or $2,000-$3,000 for another 4:2:0 8-bit internal solution that STILL requires that $1,200 accessory -- wait, why is this a choice?
Any chance you could run a comparable test with a C100, C300, JVC LS300, or any other 8-bit log? Would be nice to know if this is something inherent to 8-bit or if it's some peculiarity to the GH4...
In the HDV era there were two major grunge factors that obscured YUV smearing issues. Interlaced video encoding produced temporal aliasing and jagged vertical artifacts that were more noticeable than subtle distortions in hue. In cases where it mattered, 4:2:2 encoding was used to double the horizontal spatial resolution of the UV channels. And with shadow detail, noise levels were typically high enough to obscure blotchy chroma artifacts with clouds of randomized dither.Do you find similar artifacts in other 8-bit codecs? 8-bit digital has been used for at least 20 years, yet I don't recall anyone complaining about this issue before. HDV was an 8-bit 4:2:0 codec that was substantially more bit-starved than the GH4's 100-megabit h.264; yet, I don't recall anyone ever complaining about magenta/green smearing. XDCAM-HD on the EX1 is an 8-bit 4:2:0 codec that uses inferior MPEG2 as compared to today's modern h.264 codecs, yet XDCAM-HD's been used for almost 7 years and I don't recall anyone complaining about chroma smearing like this.
Okay, first things first -- that is astonishingly bad, profoundly unacceptable no matter how anyone wants to slice it.Wish I could, but don't have access to those cameras. For the record, here is 1080p, 23.98 AVCHD 100mbps internal V-log-L, overexposed 2 stops, in a worst case scenario image for this problem, with the Varicam LUT in FCP X--
Thank you!! for saying it like it is!Okay, first things first -- that is astonishingly bad, profoundly unacceptable no matter how anyone wants to slice it.
But -- I'm still not sold that this is an 8-bit problem. It just isn't. Can't be. People have been using C-LOG for 3 years in AVCHD, 5 years in MPEG-2 8-bit, and nobody's complained about anything like this.
That shot was from incandescent lights.Barry, do you have incandescent bulbs in your room?
Batutta, do you have CF bulbs in your room?
Could it be that VLOG exposes bad CRI?
Not unless the sun has bad CRI. ;-) That's what I've used for all of my tests.Barry, do you have incandescent bulbs in your room?
Hey mate! Greetings from Berlin!Paul Leeming--I meant to say hello. Been a while since seeing you in Tokyo. I'm doing some DRAGON vs VlogL tests that might contribute here. Not sure yet whether I'll be putting fuel or water on the fire. I think the latter.
Now that you mention it, there's a daylight CFL that I forgot about. The main light was a tungsten 250, but that CFL might have been on as well, may account for the blue.Do you have some sort of blue light in that room? Because there seem to be blue highlight reflections as well.
I pushed saturation on your image to make their positions more obvious.
