Shane Hurlbut disagrees, and recommends the sharpest lenses possible.
http://hurlbutvisuals.com/blog/2010/02/06/still-lenses/
So that proves everybody wrong who made different experiences themselves...
This is exactly my experience...I actually experienced nice results with old manual and quite mediocre sharp k-mount lenses adapted to EOS. Apart from the nice "warm" color touch, they didn't produce as much aliasing than my EF lenses, yet footage didn't look too soft. Just less harsh, giving it a more even, filmic and less videoish look out of the box.
I'm personally just fuddled with how in the world any sort of glass makes things look more "videoish" than not.
However, cheaper lenses won't give you the opportunities in low light unless you then add lighting. For me that's simply not an option in most cases and I find I'm shooting at f1.4 - f2.0 at ISO 1250 and above just to get a good exposure. F22 would be out of the question![]()
But then, suddenly, you have given up all aesthetic control of your shot. DOF and (for all you guys who's only 1.4 lens is a 50mm) framing and image styling based on field of view are all unavailable to you. You've just thrown in the towel on massive parts of your visual vocabulary.
The issue in that case isn't "cheap lenses", it's an overall cheap approach to a project. How can you afford a wide lens that shoots at 2.8 or less, but actually lighting a scene is "out of the question"? A $1500 lens and a couple of shop lights seems like a missed opportunity to me.
Exact, I mean this in no way as a personal slam against you, but rather against the sort of imbalanced mindset behind the "get the sharpest fastest glass you can afford" and thus deciding glass is the only important aspect of shot design - often (it seems) simply because one has good glass.
EDIT: Though I guess if you shoot weddings that's all moot... but I've spent far, far more $$ on lighting than lenses.
Cost really isn't the question at all.
The only important thing really is to purchase lenses that you'll use, enjoy, and try to get the most out of them.
Something to note here. Every piece of 5D Mark II footage I've shot that's been used for feature work has been sharpened in post and has had a new curve at a minimum applied to it. On top of that much of the material has been run through noise reduction, moire reduction, and has had a grain profile added back into the image to give it more of a Super35 feel. Not to mention color correction and grading on top of all that.
Great post Phil... btw... do you use the unsharp mask to sharpen? And if so, what setting do you usually go for? Also, do you have your picture profile sharpning set to 0? When you say you add a new curve at a minimum... what do you mean? And finally, do you think that the image deteriorates every time you had an image correcting filter?
