HPX250: EVF vs LCD...
kabtv
Do you think that it could be possible with a firmware update to use the EVF and the LCD in the same time ?
I should say instead that my prefect set up will be : HD-SDI for the monitor and the LCD and the EVF for the shooting. how can i do that...? Can a software update fix that ?
I'm the same boat as you. It would be nice to have the SDI out enabled as well as the LCD VF for either monitoring on a larger monitor or connecting the camera to record on an external recorder or into a computer via a AJA or Blackmagic card.
Unfortunately all of my monitors are HD-SDI, now that means I have to spend $300-$700 for a decent HDMI to HD-SDI converter.
So my question still remain unanswered, can a firmware update give us the possibility to choose which one between the hdmi or the hd-sdi we want use ?
Maybe, maybe not. Depends on if Panasonic wants to enable this feature on a lower end P2 camera. Even if it was possible, does the camera have the processing power to output both?
I just solved my problems by picking up a AJA HDMI to SDI converter, it set me back $500, but its my solution.
