Barry_Green
Moderator
DOH! Looks like Jarred posted while I was typing. Interestingly he made many of the same points...
Abaddon said:Any ideas on how to make the most of this camera at a reasonable cost?
Luis Caffesse said:That all depends on what you consider a reasonable cost to be able to shoot DVCProHD footage with variable frame rates.
Keep in mind, before the HVX your only option was a $60,000+ Varicam.
The HVX costs 1/10th of that price.
You could get the forthcoming Firestore drive for under $2000.
I'm a bit confused as to why you mentioned shooting onto $125 tapes if you wanted to shoot HD. Part of the attraction to the HVX for me is getting tape (and proprietary decks) out of the equation all together.
Luis Caffesse said:It can't record out to ANY drive, but it will be able to record to an "Intelligent" drive.
Firestore has already stated they will have a hard drive recording unit for the HVX by March of next year. It will cost under $2K (not sure on the size).
I'm almost positive the USB port is going to be used for file transfer only, not for streaming the signal. The firestore device will probably be hooking up via the FireWire port instead.
Well, of course they could have. But in their view it wasn't nearly reliable enough to serve as a professional production system. At the NAB DVXUser unveiling, Jan of Panasonic addressed that very thing -- she said that they started from the ground up, and they considered all methods: hard disk, optical disk, and solid state. They determined that hard disks just weren't reliable enough on their own -- the susceptibility to vibration, shock, heat, cold, all that stuff -- they weren't comfortable using a hard disk solution. I guess if someone like Focus wants to take the risk and make a hard disk recorder, that's okay with them, but they weren't comfortable with it. And they felt Optical wasn't reliable enough and was too slow (but she acknowledged that Sony appears to have solved the reliability questions that they had). So in their view, solid state was the only rock-solid reliable high-performance way to go.Abaddon said:Too bad they couldn't make the camera with the drive built in.
