DVX100a
w1nd
Just a noob question, the dvx100a only uses tapes, correct? I cannot record to an SD card or anything?
If tapes are the only way, what kind of tapes do I have to purchase?
I have a couple of 100As in my assortment of camera packages. I rarely ever recorded to tape. I recorded a mountain of stuff using DVRack to a laptop before Adobe bought serious magic and it became OnLocation. I picked up two long firewire cables from Laird. A 30 footer and a 70 footer. The 70 footer was about as long as you could go without using a repeater.
When I did use tape I used Panasonic AY-DVM63MQ. In fact I still have a case of them around.
Hope that helps.
So if I understand you correctly, just using the firewire you connect the camera to your computer, run OnLocation and then record it via your computer/OnLocation?
Is that the same quality you would get by using tapes?
It's all 1s and 0s. The same DV stream that's recorded to tape is what is sent out via FireWire. So you can buy miniDV tape, or record to a laptop using OnLocation or direct from camera to a specially-designed hard drive (though I'm not sure they make those drives anymore).
OnLocation has a built in waveform monitor and vectorscope and of course is not subject to tape drop out, doesn't exercise any wear and tear on the heads or put any hours on them. If everything is perfect you should be able to match the quality of OnLocation with tape but then again there are so many more variables with tape. Its digital and aside from tape drop out its either there or it isn't.
