xray said:It is fast enough, but another thing is:
If you use the external drive in FAT32 mode (so it is also easy understandable by the Mac OS) you have the problem with 4 GIG limit, being the longest clip (+/- 17 minutes DVCPRO-HD). Using it in NTFS mode (the extern. drive) solves that problem but gives other problems working with the Mac OS.
And: is the memory problem (computers with 2 Gig memory onboard ) solved in DVrack 2.0?
David S. said:Are you using a ExpressCard/34 firewire card in windows?
Or are you using a single FW bus for both cam and the external HD?
That was fixed in the V2.1 patch that was released about two weeks ago.xray said:And: is the memory problem (computers with 2 Gig memory onboard ) solved in DVrack 2.0?
It will split the file if you use FAT32. Also, the Mac can read NTFS, so if you don't need to write to the drive from the Mac, then you can avoid splitting the file into 4GB chunks. Another option would be using MacDrive on the Windows side to enable read/write access to a Mac-formatted drive.FatBird19 said:ok. Will it just stop recording at 4GB or will it just split the file?
THoff said:That was fixed in the V2.1 patch that was released about two weeks ago.
THoff said:It will split the file if you use FAT32. Also, the Mac can read NTFS, so if you don't need to write to the drive from the Mac, then you can avoid splitting the file into 4GB chunks. Another option would be using MacDrive on the Windows side to enable read/write access to a Mac-formatted drive.
FatBird19 said:What's MacDrive?
David S. said:There's this cool new search engine on the internet called Google:
http://www.mediafour.com/products/macdrive6/
