acentofante
Okay, here is the problem...
I shot some footage on my hvx200 at 720p30 and then changed it to film mode and put the frame rate at 60 to get some slow motion shots.
When I bring it into final cut pro it comes in as 720p60 (59.94) and when I try to use the frame rate converter I get this error message
http://www.okayyellow.com/errormessage.png
as you can see the footage matches exactly what the converter says it needs
I also tried to pull it into cinema tools but the conform button is grayed out
I did a few tests using the 720p60 settings and again get the same error message!
any ideas?
thanks!
any ideas?
thanks!
