Hello-
I am a freelance DP and am trying to come up with a simple workflow for my typical projects. I got the HVX200, a P2 Store and several 8gb cards a year ago, and in the mean time have bought this laptop (MacBook Pro Core 2 Duo - been all Mac since 1984) and a Dual Systems adapter.
For this camera to work in my situation - I need to deliver all the footage at the end of our day, to the producer or client, who may or may not be local.
To this end I need the fastest, easiest way to dump the footage from the cards onto a (typically the clients) hard drive.
First - I was using FCP to import and then save the QT files to the drive, with the P2 Store as a card reader. I did have problems with a few clips (using FCP 5.1.4) so changed my workflow to
Second - I stopped using FCP and simply 'drag and dropped' all the contents of the card into differently named folders on the clients drive. Again with the P2 Store as a reader. Now the clients had all the original files - and they could use any NLE. With this workflow - I had no issues with footage - but I still couldn't PLAY the files to really check that they were ok.
Throughout all of this - I always copied the ENTIRE contents of the card, and used the camera (not the computer) to reformat the card after I knew the files were transferred.
Now- with the release of Leopard - I can use the Dual Systems Adapter as the reader (much lighter and easier to use than the P2 Store).
but - BUT
Now I read that what I have been doing is wrong and I am jeapordizing all my footage by using drag and drop.
I have P2CMS and have been trying to make it work.
It is not intuitive, the manual has some of the worst translation I have seen and it's almost unintelligible.
When I use P2CMS to read the card and ingest to my firewire drive - it seems to work - but it cannot read the files it just copied - saying it has a 'confirmation error'.
So then I read Barry's advice - which I am trying to follow - and use P2CMS to 'export' the footage (export from the card to the drive? what's the ingest button for?).
But P2CMS wants to erase the footage as it exports - which doesn't work when you have the record tab slid over. Why can't I export the footage WITHOUT erasing it.
I would like to test the files I just transferred (exported, ingested - whatever) BEFORE they are erased.
So the result is that with P2CMS I was unable to get the footage from the card to the drive (I didn't try to let it 'export' & erase the footage, and after ingesting - P2CMS was not able to read the files it just ingested!!)
So I tried the old (apparently unstable after being fine for ANY other computer file for the last twenty years) 'drag and drop' - and guess what - it worked! and even P2CMS was able to read the files from the firewire drive.
I was initially mad at Apple for having such issues - but I believe now the ball is in Panasonics' court. If they want the production community (as opposed to the news community) to embrace P2 - and a much higher percentage of production is Apple based - Then Panasonic needs to make it easier for us Apple users to use their product.
For now I will use the Dual Systems adapter as a card reader, and drag and drop the contents to the target drive, and then use P2CMS to check the files before I format the card.
but - BUT
