the final output is the same codec, but the way the picture is encoded is different, so you get the same specification file with a diferent quality (lower on the t2i)
it is like filling a bottle with different content, if the matter is to open the cap, you do not really care about what is in the bottle.
On the other way, if your problem is mixing the content of different bottle, you could have some concern about the content, to see if they match.
anyway you can hardly work directly with files produced with thses DSLR, the best would be to convert first to a better codec.
This is NOT about 5D vs 550D this is only a technical question about postproduction:
when I test material of the 550D and it works, can I also use the 5D material with Avid without problems?
As far as I know all canon DSLR footage (550d, 7d and 5d) are the exact same format.
Thanks!
So if material from 550D works I take it 5D material also works with MC4.
Perrone: do you transform to DNxHD or how do I get best quality output?
