radtex said:So, do you think the DiscoveryHD channel will accept hvx as good enough for their HD channel?
Anyone know a link to the Discovery HD channel producers guidelines?
stabwound said:Alex:
Is that what shows like Discovery Channel is using... HDcam format?
I was going to do something for the local cable company (volunteer fill footage) and wondered if there was an accepted HD standard.
They don't take 35mm, they accept 35mm originated content that has been telecined and delivered on HDcam 1080i.alpi69 said:how big is the difference in shooting 720p and 1080i and 1080p when seen on a HD screen?
if they take 35mm then 1080p should work just like 1080i. I never saw 720p footage, so i don´t know how that holds up against 1080i/p.
The biggest problem for shooting for discovery with the HVX is the short lens. a Canon HDV has a better lens for that, but then that is HDV...
ChuckS said:They don't take 35mm, they accept 35mm originated content that has been telecined and delivered on HDcam 1080i.
ChuckS said:Gibby's suggestion about shooting in 1080i instead of 1080p, to avoid any potential conflicts later in the post production process is a good suggestion. The only recomendation that he made that I migh change, only after doing a test to make sure which provides the better quality, would be to edit in DVCProHD and then output HDSDI to an HDcam.
overlandfilms said:There are contractual specifics, on a show by show basis, for ratios of HDCam to other formats - HDV included. HDV in its native format does not conform to DCI HDTheater standards, and that makes it an expensive proposition.
Everything acquired in 60i HDV must be "uprezzed" to HDCam - we had about 2000 hours done on Driver X. The best part is keeping your HDV shooters at exactly 40 minutes (or less) on a 60 minute tape - fun. If you've got a one-off, this isn't a big deal, but if you've got thirteen or twenty-four or six... well, now you're talking about some real money.
I have a pitch underway for DCI, and we've kinda been told that Panasonic's 720p, which is our preferred format (variable framerates) for this particular property, isn't likely to be acceptable for HDTheater.
The problem is, DCI doesn't seem to want anything to originate in SD - regardless of whether it is intended for HDTheater markets at all. Add to this their hard-on for 1080i right now and you've got some hoops to jump through.
ChuckS said:Hi Gibby,
I'm cuurently using Cineforms AspectHD to convert HDV to an intermediate HD format. So far the quality is quite good. I'm not doing this in hopes of being able to pull the wool over the eye's of anyone requiring an HDcam master, however, I am hoping that this workflow can be used with DVCProHD [or any other format] so that I can develop a standard for post that would allow me much more flexibility in mixing formats and yeild whatever format required for output.
For the record, Canada uses the same video standards as the USA.Gibby said:If your local cable company has a dedicated HD channel, my guess is that it would be 1080i60, or possibly 1080i50 since you are in Canada...
alpi69 said:we delivered a lot of DV-shot footage on BetaSP to networks which officially didn´t take DV. I expect it to be the same with DVCpro and HDCam. If the content is highquality (which Discovery always is!) then a well made DVCProHD film from the HVX should get accepted on HDCAM
jessecoane said:I've heard that discoveryHD will also except sdx900 footage. Thats the only SD footage they wil except.
jesse
