might just be this particular vimeo upload but wow the IQ looks no better than a modern smartphone. was expecting more especially since the lighting in these arenas is very good, lights for TV good.
not good to hear about the fan noise as well.
david
That's just the way the camera looks. The compression artifacts are pretty noticeable no matter the light. I saw a comparison video online between the X3 and iphone 6s and the X3 was substantially better, so there's that. The 1080p and 4K look almost the same due to the compression issues.
It's probably because most of the reviews are based on using the Osmo in the field, rather than on set. A lot of the early adopters are drone operators, as well... Compared to a quad copter, the Osmo is probably whisper quiet
Most people will probably be using it for b-roll and field Photography where sync sound isn't critical. Like on mountain tops. It's windy at 12,000 feet, but if it's had an Osmo I could have gotten some 4k footage from the summit of Mt Adams. ��
The big question for me is whether the x5 has a fan. I've looked at images and I can't see fan vents, so they DJI might just be using a heat sink. I don't think I would want to use the X3 for narrative with dialogue anyway as the camera is basically set for inifinity focus and the look of camera is too much of a compromise. The x5, however, has options for different picture profiles and focus control built into the app. The motors themselves are not too loud, so if the x5 doesn't have a fan I would definitely pick it up and keep the x3 for quick b-roll and the times that I want to strap the Osmo to car or something.
Am I reading this right, the camera is 60/mbs 4:2:0 at 4K? Seems a little expensive for a $2400 kit. Considering the GoPro 4 has the exact same 4K codec, added with a small 3-axis gimbal, comes to around $600.
I know the X5 has a bigger sensor, but what a terrible codec to put in a camera like this. Even at 100/mbs 4K there is some noticeable compression, I can only imagine what it looks like trying to grade footage at 60/mbs 4k.
Yeah, I was expecting the x5 to have a better codec. The x3's codec is pretty bad, and the compression artifacts are glaringly bad in every test video I've seen so far... but it's hard to tell how much of that is due to being hosted on YouTube, since YouTube compression is quite bad.
It will look just fine, especially for the web. Where 99% of our stuff ends up anyway.Am I reading this right, the camera is 60/mbs 4:2:0 at 4K? Seems a little expensive for a $2400 kit. Considering the GoPro 4 has the exact same 4K codec, added with a small 3-axis gimbal, comes to around $600.
Yeah the compression is awful for 4K and HD. The footage works for quick cuts or masters, but for any kind of jig/crane type shots it's unusable.
https://www.youtube.com/watch?v=OpJ2L8CpITwI suppose using it in actual film production will have to wait until I can afford an x5r then. Unless DJI plans on updating the codecs to something less terrible, I'd call the x5 a waste of money, and the x3 only worth it because it's so inexpensive. Even so, the glaring compression artifacts are making me hesitant, because what's the point if the footage isn't usable for anything but youtube?
