First, the Bogen 325N is for tripod heads that have the 3/8" screw sticking out of the bottom. This is rare... most heads have a threaded hole and require a mount that has the bolt sticking up. I'm not familiar with the DS-10, but I'd think that you could separate the head from the ball base and find a standard mount. For that, you need something like the Filmtools 4" riser.
As for mounting the rail to the tripod, you'll use the now-separate ball base, that should have the 3/8" bolt sticking up. (and I presume that you've already thread-tapped one or more holes in the IGUS rail).
I would highly recommend, however, that you get a second tripod head and mount it to the carriage, then mount your rail to the quick-disconnect plate for your DS-10. Having the rail on a tripod head makes things oh-so-much easier.
But now I am not sure how to fix the rail on Miller Solo tripod legs and the Manfrotto by Bogen Imaging 325N does not seem like work with my Miller DS-10 fluid head on the carriage.
Anyone tried this with a Miller solo tripod and DS-10 fluid head.
That's my tripod and head. I have a special plate at the bottom of my rails ( one is 24" and the other 45") it increases strength as Aluminum threading is not a great long term solution. Pictures....
I haven't read through all 90+++ pages. Just wondering if someone can tell me what options are available for making these end pieces, like on the Glidetrack ...
I see. Boat bumpers will keep the carriage from sliding off the rails. What about actually elevating it slightly off the ground, like those end pieces do for the Glidetrack? Like for when I won't be using a tripod?
I noticed someone used a 2X4 ... or maybe it was a 4x4? Any other solutions out there?
Thanks.
Again...first post. I used 4x4 pieces of wood and a couple eye screws. It's dirt cheap to do, gets the rail 4" off the floor and the eye screws stop the carriage from sliding off the end.
Maybe you have a special application, but I don't use this much on the floor, so the wood block are the perfect solution for me.
Here are pictures of my slider that I just received today. Very well made and came ready to slide. $99.00 PLUS $12.00 SHIPPING.
http://www.youtube.com/watch?v=iMgT-PmEBPQ
Your point? In case you hadn't noticed, this is a thread in a forum for building things yourself.
While the IndiSlider Mini certainly breaks the previous price-points, you do get what you pay for. Initial reviews have reported it to be useful, yet not quite as robust as the IGUS rail and carriage. And the mounting hardware on the Mini's carriage isn't nearly as solid as what we're building here.
Don't get me wrong... I'm not dogging Tim at all. IndiFocus makes some neat, low-cost stuff (I have the rails and matte box). But when it comes to priceerformance, I have no regret that I opted to order the IGUS parts and assemble this thing myself for about $200, getting the performance I'd have gotten out of a $400-500 pre-assembled rig from other companies.
EDIT: Watched one of your links (the other didn't work). Lots of wobble. Part of that might be in getting used to using it, but it didn't seem too stable.
And there's an on-going thread discussing your particular slider HERE.
From what I have seen the Igus has more hesitation and wobble than the Indislidermini, and I also understand that you will have a bias on your observation, having the Indislider on the wrong forum. There is always room for improvement for both systems, just want you to be more factual than being bias next time.
I'm ordering mine and have some ideas for motor mods. I'll post some video when it's done along with how I made it. Thanks guys!
Welcome to DVXUser!
Last, I wonder if ZazaCast had any clue how much this thread would explode when he first posted it!
