Has anyone found something equivalent to the 4" riser that can be bought in the UK? I want to raise my head so I can do dolly shots on the slider but the 4" riser would cost far too much with shipping to the UK.
^ I just shipped a ZazaSlider Basic to Qatar for $310.00 USD.
How long is the wait usually to ship out the Basic Slider? Im located in CA. Thanks in advance Zaza.
If in stock, they go out the same day. If I need parts, it's about two days.
I'll have stock Thursday this week. :thumbsup:
I just built a slider and have a few basic questions. I have read a ton in the thread but still have a few.
How quiet is it supposed to be? Mine feels pretty smooth and doesn't bind and isn't terribly loud if I push it fairly slowly. How fast do you guys push? I have looked for videos on Vimeo of the slider itself in action(not test footage) just to see what it should be like. Anyone have a video that shows the carriage sliding on the rail? I have never used a slider so I have nothing to reference from.
I have gone through the alignment instructions a few times and I feel like it is aligned fairly well.
I have built my Igus slider and was really happy until my friend bought from Pacific Bearing and I got to tell you you barely push his rail and it SLLIIIIDDEEES. Mine you have to put a little effort into it. I should have bought the PBC product.Here's the page to pick your sliders and rails. Pretty confusing at first. Hope this helps if anyone decides to go with rollers instead.
http://www.pacific-bearing.com/workarea/downloadasset.aspx?id=8226
Hi guys,
I'm currently using a tripod head that is meant for photography, it has a short handle, and I it's not very fluid / smooth when I start moving the head from a dead stop, and that transcends to the video footage.
Once I am moving, motion is very smooth, but it's that little jolt I get when I have the head not moving, then go into the motion of moving it. I'm pretty sure it is not the length of the handle ( short ) , but perhaps I'm wrong ? ...
is a video head different just because it has a longer handle ? or is there something else in a video head that is different from a tripod head that is meant for photography ?
What do you suggest as a video head that won't break the bank ? I'm guessing there is some sort of preference that most of you use ?
thanks for any info !
I have one of these...or the earlier version and it works great. Nice & smooth. Got it on eBay for $75.00. It's what I use on my slider too!
http://www.amazon.com/Manfrotto-701...1?ie=UTF8&s=electronics&qid=1274973993&sr=8-1
you got yourself a good deal, make that a great deal. I just checked eBay and the lowest I see is $145.95
Can you talk about the smoothness, and do you think the long handle adds to that smoothness ?
I guess what I want to know is how smooth is it from a stop. So where you may have it locked down to shoot something, then you slowly loosen it, and now start moving..... panning around etc.
Do you think it is just the longer handle that aids in smoothness ? or is there something else extra on the head that accomplishes this ?
- and thanks for the information ! :laugh:
A fluid head literally uses fluid, i.e. viscous oil between the mechanical components that allow the smoothest movement. A quality fluid head will allow for the subtlest of movement with clean starts and stops, as well as jerk-free pans. They are not cheap, but are an absolute must for anyone who is looking to deliver work that is beyond home movies.
There are also "fluid effect" heads that are a notch down, using a lower grade lubricant to simulate the effect to a lesser degree.
Friction heads are usually meant for still photography where moves are not critical. If a head offers the ability to tilt 90 degrees to the side, chances are it is not intended for film/video use, rather it allows still photographers to compose in the vertical format.
Charles Papert
I don't know about the head you're using, but video heads are 'fluid' heads and allow for much smoother movement. If you've never played with one...you should....you'll notice the difference right away.
The more you spend, the smoother the movement! (that goes for a lot of things in life...LOL)
Here's a good explaination:
