LuckyStudio 13
The Tapeless One
A good guide for you aspiring Discovery Channel shooters.
Non-HD Footage Limitations:
Maximum of 25% non-HD material is allowed in production, with no more than 1 minute of contiguous non-HD footage in any sequence.
Use of HDV Footage:
1080 line HDV footage may be used in HD programs with the following restrictions:
Program may not contain any more than 15% HDV footage.
The combined percentage of HDV and SD upconverted footage is not to exceed 30%.
Producers wishing to use HDV must submit an approved post production path outlining their handling of the footage in the editing process.
Video Footage:
Video Footage should be acquired using any of the following formats, taking in the non-HD footage and HDV footage limitations above:
High Definition Formats Acceptable Up conversion Formats
( Film Formats )
70mm Film
35mm Film
( Acceptable Up conversion Formats )
Sony Digital Betacam
Sony Betacam SP
Panasonic DVC PRO 50 (tape)
Super 16mm Film (non-HD Guidelines)
Sony MPEG IMX 50 (tape)
Sony MPEG IMX (XDCAM)
( High Definition Formats )
Sony HDCAM
Sony HDCAM SR
Sony XDCAM HD (35 mbps only)
Panasonic DVC PRO 100mb (HD)
Panasonic HD-D5 (Film Transfers)
HDV at 1080i (with restrictions)
HVX-200 DVC PRO HD 100 (with HDV restrictions)
( 720P Camera Masters )
720P material is acceptable, only with a pre-approved post production path and budget. Delivered Master must be at 1080 resolution.
Footage may not be converted from 1080i to 720P for post and converted back to 1080i for
mastering. We cannot allow multiple resolution changes on material. If you have an editorial need to use mixed resolutions, please discuss this with us.
Film Footage Transfers:
35mm Material – High definition datacine transfers of this material produce perfectly acceptable results.
Super16mm Material – High definition datacine transfers of this material do not currently produce results that
are acceptable for usage in Discovery HD programs. Usage of this material is limited to non-HD footage guidelines.
DVCam and Mini DV – High definition up conversions from footage acquired using these formats do not produce results that are acceptable for usage in Discovery HD programs (DVCPro HD is acceptable as noted above).
Visual Effects and Footage Treatments:
Any visual effects that seem to add grain or noise to acquired material require pre-approval by Discovery’s Network Presentations Department (sample materials will need to be provided). As with film and lower end digital video formats, any significant video noise or film grain will potentially create complications during distribution.
VIEWER ADVISORIES
Disclaimers will count as program content, and will be edited onto the broadcast master by the production company.
Disclaimer Placement:
Disclaimers must be placed at the beginning of the program and at the top of each program segment.
Discovery’s Executive Producer assigned to the program must approve wording of the disclaimer.
All Disclaimers shall use the following Format:
Black background, white text
No Discovery logo, no music
Must be voiced (preferably by the narrator)
Minimum: 06 seconds in length
The following are examples of advisories pertaining to sexually explicit material, coarse or offensive language intended for adult audiences, or other subject matter.
They are provided as a guide to assist broadcasters in fulfilling their obligations to the CAB Code of Ethics, to ensure their viewers are provided with adequate information in making their program selection.
"The following program contains scenes of coarse language and is not suitable for younger children."
"The following program contains sexually explicit material intended for adult audiences. Viewer discretion is advised."
"The following program contains sexually explicit material. Viewer discretion is advised."
"The following program contains scenes of violence, coarse language and nudity intended for adult audiences. Viewer discretion is advised."
"The following program deals with mature subject matter and is intended for adult audiences. Viewer discretion is advised."
"The following program deals with mature subject matter and contains scenes of nudity and coarse language. Viewer discretion is advised."
Look at the Specs Here.
Use of HDV Footage:
Video Footage:
( Film Formats )
70mm Film
35mm Film
Sony Betacam SP
Sony HDCAM
Sony HDCAM SR
VIEWER ADVISORIES
