I literally just tried it to check that I'm not drunk. I assumed one would understand that the two frames that Dynamic Zoom offers represent the start and end frame.
The Green frame is start and the Red is end. You can resize and position them as you like by dragging the corners to change their size and the frame to move them. It's a very visual interface and it takes no key framing at all, and you don't need to "set" anything. In his example the frames are cropped in and would have the Green on the left and Red offset to the right.
I would say it's half the work compared the screencast the OP is offering. But what do I know.
Dynamic zoom will work fine for two fixed positions like beginning and end. You need to go to inspector to get a more complicated motion like a pan and zoom with many movements within the clip.
Why do you want to use Resolve ? It is still fast in inspector if you know what to do. It just isn't graphical like Vegas using the mouse. Size with zoom, position with X & Y set keyframe, set new position and set key frame. Done.
That dynamic zoom sounds nice....I wonder if theres an equivalent in FCPX
The only issue with this approach is...
My comment was for Unicus as I was curious as to why when he demonstrated what he wanted to do with Vegas why was Resolve so important to him. As you can see I have Vegas 18 as well as EDIUS and Resolve . I have had Vegas since it was just an audio editor so know it well. If you read my posts I view Vegas as the best to do this sort of thing. If you need to stay in one program and do everything then I would think Resolve has the edge.
Yes. It's intended to be used with a Start frame and an End frame in mind. Not multiple back and forth—which if course can be done via normal key framing. But I don't remember suggesting anything more complicated than what the OP showed in his clip.
What's nice about the Dynamic Zoom is that there is no key framing involved, you can extend or shorten your clip and still maintain the effect without needing to adjust it. As in your example you mention, you will also see the whole actual frame of footage, as well as the Start and End frame while adjusting everything. It seemed like a great fit for what the OP needed.
I get the feeling that the function in Vegas, if it lets you place keyframes, isn't dynamic. That is, it won't self adjust to changes in clip length? Not that it matters, but I don't think it's the same function. It sounds more like a visual GUI to place keyframes?
And in the end it didn't matter. It seems he opted to go with keyframes.
