Hope someone can give me some pointers to refine my workflow. I'm trying to get the best possible quality from the D7000. Here is what I do at the moment:
Capture
Shoot manual 1080P24, 1/50s shutter speed, aperture for desired depth of field, ISO for correct exposure (close as possible to 100) - use ND filter if outside.
Picture control - modified standard, sharpening 0, contrast -2, brightness 0, saturation -2, hue 0.
Post
Import to AE CS5
Edit native footage (not transcoded)
Stabilise footage (if necessary)
Apply s-curve to correct for the flat shooting style, maximising dynamic range and rolling off highlights and shadows
Correct white balance
Apply desired 'look' using colorista or similar
Use unsharp mask to sharpen
Slice and dice in Premier CS5
While my results are OK, there is plenty of footage I have seen from the D7000 which is better and I was wondering what fellow D7000 users do differently with their workflow. Is there a better picture control, maybe like the technicolor log cinestyle? Is my PP process/order as good as it can be? Thanks for comments.
Capture
Post
Import to AE CS5
