prores 1920x1080p24 should work well including rt playback and fx. haven't tried it myself but that's generally how prores timelines perform. i wouldn't want to edit in h.264, too much loss of quality after rendering (if you're a power user and use fcp 6- you can edit in one and render to another, but that's beyond easy setups).
On a i7 2.8 ghz quad processor.RT = real time playback. FX are video effects/filters.
I agree with mattsand that it may be a good idea to recompress everything to prores BEFORE editing. FCP definitely works more smoothly with prores than H264. Even so, I would use the method listed above to set the timeline to match the clips.
But if your computer is fast enough to edit in direct H264 (as it comes off the camera) then it's nice to be able to use the files natively without recompressing. Quality is not an issue - after editing, change the timeline compressor to the prores (or something else) and re-render or export.
Yikes. These file sizes are going to be ginormous. Going to need 2TB drives!
Could the conversion to Prores be done in MPEG Streamclip?You should use compressor to batch convert all of your clips. Load them all into compressor and output Prores with all of the same settings as the originals.
Then edit with those clips. After you import the prores clips into FCP, drag one into a new sequence and the sequence will set itself to prores (if you answer yes to the question). The prores clips will give much more real time functionality and won't require render as long as the sequence and the clips share the same settings (which they will, as long as you answer yes to that important question).
no, which is my whole point. prores timelines are realtime regardless of what you drop on them.But if you use H264 clips in a prores timeline, you'll have to render each one as it's added.
