FiddlerMD
Hi everyone, I bought a D7000 this morning and am trying to figure out a good audio solution. Options are to run a mic (a lav) directly into the camera, get an external recorder or combine the 2 and run the external recorder into the camera.
Obviously option 1 is easiest but I'd like to know from those that have tried it whether it's worthwhile - meaning, is the quality of the recording sufficient or is it too noisy/bad otherwise for this to not even be a consideration?
as far as recorders go, I could go with something like a Zoom H1 but then I cant easily use my existing xlr mic (oktava) if I want to. Then there's the tascam DR40 which seems like a great recorder with xlr but it does not have a line out.
can someone explain to me why you'd run an external recorder and then also run it into the line in on the D7000? is it strictly for sync or do you have a better reason for this?
Any comments on the best solution for D7000 audio will be much appreciated - thanks!
