Coco Bermudez
Superb 30p to 24p Workflow
1. Create copy of clip so you'll have two clips, one to convert to 24p and one to preserve audio.
2. Open Cinema Tool (part of Final Cut Studio), File, "Open Clip", choose "Conform", specify "23.98" to conform to.
Explanation: This keeps the same number of frames in the clip, it only changes the timebase from 30fps to 24fps, essentially creates overcranked footage by 6 frames, (desirable on some shots). As a result this makes the clip longer and slows the audio down which is undesirable where audio is important. At this point you've already created a copy of the original clip therefore preserving the original audio which we'll relink later in Final Cut.
3. Now we'll convert the clip to a desirable format for the workflow and effectively speed the clip back up so you get desirable 24p realtime results. Using Compressor 3 convert the clip to any of the following settings:
* Apple Pro Res
* Apple Intermediate Codec
* DVCPRO
Important: Make sure that no matter which codec you use that it remains as a 23.98 fps timebase.
Now open the inspector window so we can do some tweaking. Under "Frame Controls" tab, click the button to the right of "Frame Controls:" to enable this feature. Once enabled, select "On" for "Frame Controls:" Underneath the "Retiming Control" section is where we'll make changes. For "Set Duration to:" click the radio button where it will allow us to put in a percentage. The magical number we'll want to put in here is 79.996%, then depending on how well you want the footage to look also taking into consideration the time it will require to compress it choose the desired quality under "Rate Conversion:". I choose, "Best (High quality motion compesnation)" to get superb results, however this increases the compression time.
Now, what have we done here? We've converted the unusable H.264 format into a format we can edit in and sped the footage back up to original duration using Apple's Optical Flow Technology.
4. Now take the treated clip into Final Cut insuring the timebase is 23.98, delete the audio track and add the audio from the copy of the clip we made. Now relink and presto!
I've extensively tested this and find it to be the best way to convert 30p to 24p for the time being, or atleast until and hopefully Canon comes up with a firmware to address the issue.
Additional Tips: If you have multiple clips to treat, in Cinema Tools, choose "Batch Conform" locate one file where all the files are located. Then setup batch conversions in compressor, if you have a quad core or 8 core configure Q master to take advantage of all cores otherwise it will take longer.
One final note, depending on the specific needs of your project you may need to treat many individual clips or take your finished project (of course h.264 has been converted to an editable format) and follow the steps above to get great results. I've tested a 9 minute clip and was able to complete the compression on an 8 core in one hour and a half.
Bests,
Denver Riddle
good stuff..thanks for this.
Do you have any footage with the original and treated version to compare?
